White-grey exhaust smoke for a few moments. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-18-2013, 07:01 PM Thread Starter
I noticed some white smoke for a few minutes the other day and was wondering if I should be concerned.
The truck is an 06 with just under 90K. I have an SCT live wire from IDP. I am running the street tune, and other than a coolant filter the engine and trans are stock. I use the SCT for engine monitoring and my ECT and EOT delta averages 8-10 degrees. I usually run a B20 blend fuel from a reputable station with a high amount of turnover.
The other day I was leaving the beach after being parked for an hour or so and noticed the exhaust was a white-grey color as I left the parking lot under load. The ECT/EOT was around 150 degrees so it wasn't quite warmed up, but being a 6.0 I immediately started to freak out a little. I kept watching the exhaust for the ride home and every time I would pull away from a light I'd get the usual puff of all black smoke as I pulled away and the turbo came in. It also hasn't done it since, but I haven't had a chance to recreate the scenario above (the surf's been pretty flat!)
Any thoughts as what to look for? None of the searches I did seemed to match up.
w00ht is offline
post #2 of 5 Old 09-18-2013, 07:59 PM
drivininidaho's Avatar
Quoted: 87 Post(s)
Run truck up to temp then pull egr valve check to see if there is liquid in there. Could be your egr cooler failing. Did it smell sweet?
Also consider HG.
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #3 of 5 Old 09-18-2013, 08:29 PM
somthin333's Avatar
I have the same problem with my 6.0 and it worried me too. I also have the SCT tuner from IDP. I read some about it before and the best answer i could find was because of the excess fuel from the tune, and injector stiction becoming a bigger issue with more fuel until the engine warms up. If i returned it to stock the smoke went away so and i have an egr delete so i don't think its that, at least in my case....and really hope its not HG's Still haven't found out for sure what the issue is though so i am curious what other ppl have to say.
somthin333 is offline
post #4 of 5 Old 09-19-2013, 01:30 PM
Quoted: 87 Post(s)
Compression test is none way to determine if its your HGs
Lyndel
'04 F25 SD CCSB
post #5 of 5 Old 09-19-2013, 03:13 PM Thread Starter
I couldn't smell anything, but it wasn't steam since it lingered in the air for a few seconds before fading away (not evaporating). I also just changed the oil and it looked fine. The coolant color is normal as well. My buddy is a TDI guy and said it sounded like an injector balance issue. I've been driving the truck all week and haven't noticed anything abnormal with the gauges or exhaust smoke.
I think I'm just going to keep an eye on it for the time being.
Does anyone have any idea what PID's I should monitor for the injectors?
w00ht is offline
