Condition of my EGR valve - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-18-2013, 11:13 AM Thread Starter
Dadepowerstroke's Avatar
So I decided to clean out the EGR valve today and when I took it out it looks to be in terrible shape.Lots of soot and moisture.I believe the valve had never been cleaned but what is up with the moisture?Any help would greatly be appreciated.
Dadepowerstroke is offline
post #2 of 7 Old 09-18-2013, 11:21 AM
ZMANN's Avatar
Quoted: 1586 Post(s)
it's oily soot
if your worried about the cooler park the truck nose down overnight then look at the manifold after you pull the valve
for now clean it up per the directions get a o ring kit and put it back in
We Miss you Ronnie
ZMANN is online now
The Following User Says Thank You to ZMANN For This Useful Post:
Dadepowerstroke (11-24-2013)
post #3 of 7 Old 09-18-2013, 11:36 AM Thread Starter
Thanks ZMANN.
post #4 of 7 Old 09-26-2013, 02:46 PM Thread Starter
After a week of thinking about the wet stuff on my egr valve and intake manifold I finally got a chance to park the pickup nose down and when I looked inside today I saw that the egr valve was dry,but there was some black fluid at the bottom of the manifold.What can this be?
post #5 of 7 Old 09-26-2013, 02:54 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Black fld...well your egr cooler could be failing. Or this could be from the crank case vent. Check out the ccv mod. And probably a little late but remember to use carb cleaner not brake cleaner when cleaning the egr valve.
Good thing is you can delete the egr cooler and do the ccv mod and take care of this issue!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
The Following User Says Thank You to kinnisoj For This Useful Post:
post #6 of 7 Old 09-26-2013, 03:00 PM Thread Starter
I smelled the fluid and it didn't smell like coolant.What is the ccv mod?
post #7 of 7 Old 09-26-2013, 03:42 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
ccv= crank case ventilation mod.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
