NO hot start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-16-2013, 04:57 PM Thread Starter
585Amarillo's Avatar
NO hot start
My truck has 67,000 miles and when its cold it starts (long start) somtimes and when its hot it doesnt start unless i unplug the ICP sensor then starts.
Does any one know why , I'm thinking its either bad sensor, bad dummy plugs/ stand pipes, or STC fitting. I'm thinking of buying auto enginuity what do you guys/ ladies think?
K&N Intake
MBRP 4" Turboback
Silverline 6" Black Aussie Stacks
Zoodad Mod
Ford Updated parts
BPD FICM
Blue Fuel Pressure Spring
ARP Head-studs
Stock Injectors?
AirDog 165 Fuel pump
EGR Delete
SCT Custom Tuner By Inovative Diesel 5 tunes
10" Lift
37" Toyo Open Country M/T
4.56 Gears
18" XD Thump Black Wheels
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
Glowshift Gauges Trans.Temp., EGT, Fuel Pressure
585Amarillo is offline
post #2 of 5 Old 09-21-2013, 03:24 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Definitely get a monitor. I believe an AE can control the IPR so you can do an air pressure test on the HPO system. It could be a number of things... Start with getting icp, IPR, and FICM volts. Make sure you look at icp volts and not psi because some tunes alter the icp psi number for more power.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 5 Old 09-22-2013, 04:48 PM Thread Starter
I just bought the revised standpipes, D-plugs, stc, turbo feed and return and auto engenuity do you have any experience with it
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #4 of 5 Old 09-22-2013, 06:50 PM
Quoted: 8 Post(s)
I have never used the AE, or are you asking about doing an air pressure test on the HPO system?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 5 Old 09-22-2013, 06:59 PM Thread Starter
i was asking about AE. you guys have any advice on the stand pipes like does the oil rail need to come out to install in the tq specs on the plugs, stand pipes, and hpop cover.
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
