Vibration at 50.... - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-16-2013, 02:01 AM Thread Starter
Fosterslaw77's Avatar
Vibration at 50....
Ok it's an 06 f350..... Had problems with tire balance etc ended up new rims and tires due to cracked rim. Previous I had rear axle seal replaced had a small vibration at 70, chalked it up to tires. Then I had new carrier bearing and new u joints installed. Now truck starts vibration at 50, bad enough shakes mirrors. Still does it with new rims and tires exactly like when I had other sets of tires and rims. Does it from 50 on feels like a tire not balanced but can't drive out of it. Any ideas since I already had u joints and carrier replaced. Gotta take it back to shop but wanted to get some ideas to assist them. They are a little baffled by it as well. Thanks
79k on it
Fosterslaw77 is offline
post #2 of 8 Old 09-16-2013, 02:48 AM
Is this thing lifted or modified in any way?
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 8 Old 09-16-2013, 02:28 PM Thread Starter
Nope stock truck
post #4 of 8 Old 09-16-2013, 02:34 PM
SuperCrutyPS's Avatar
Quoted: 312 Post(s)
Garage
Does the drive shaft show any signs of a weight being on there and is now missing?
I've heard of guys clocking the drive shaft too. (disconnect from rear diff, rotate 90*/180* one way or the other)
Just throwing out some things I would try - Don't know if it will fix anything.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #5 of 8 Old 09-16-2013, 03:54 PM Thread Starter
I took it to shop today they gonna take off the shafts and send em out to check em for balance. Said he's seen it before especially we use a bunch of salt here in the winters rust or weight comes off cause of rust. So I will see by Friday I hope. What is clocking the shaft, what does that do to it.
post #6 of 8 Old 09-18-2013, 11:23 AM
elchaseo's Avatar
Quoted: 8 Post(s)
There is alot on these forums about this. I have a bad hopping from the rear at about 45-50 keep us posted on how it goes.
2015 F250 Lariat- CAI, CCV Reroute....more to come
elchaseo is offline
post #7 of 8 Old 09-18-2013, 12:44 PM
My 04 excursion had a bad vibration right around 50, then picked it up again around 70. Of course the 2 speeds I travel at most often. Got worse and worse and I was ready to take it to a shop, changed the tires and the problem went away with them...
hasteranger is offline
post #8 of 8 Old 09-18-2013, 03:30 PM Thread Starter
I should get it back Friday driveshafts at balance shop so we shall see. Def not tires or rims these are brand new and it did it with old ones exactly same speeds
