Can't shift out of park - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-15-2013, 04:13 PM Thread Starter
Roadking's Avatar
I have a 2004 6.0 Super Duty. A couple of years ago I started experiencing shifting problems. Specifically, it won't shift out of park until it's good and ready. I have never been stranded for more than a couple of minutes. But I know it is only a matter of time before I am stranded for good. Can anyone tell me how to fix this before it is too late
1969 MGC
6 Cylinder 4 Spd / OD
Loves to go cross country
Roadking is offline
post #2 of 6 Old 09-15-2013, 04:45 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
Slop in the shifter not allowing the shift from park solenoid to disengage or a bad solenoid or loose connection could be the culprit. These trucks are famous for wear in the shifter. Sometimes noticed by having to "hunt" for a gear position other than P R or D. Takes about an hour to replace two small plastic bushings on top of the column that the shift rod rides in. My Ford dealer had a pair in stock for less than $14, and some auto parts stores may carry them. Ebay has loads of 'em.
2002 F-250 LARIAT CCSB 7.3 AUTO 4X4 261,XXX
2004 EXPLORER XLT 4.0 AUTO 2WD 130,XXX
1966 MUSTANG COUPE 289 4 brl V8
IN-LAWS...
2004 EXPLORER SPORT TRAC 4.0 4X2 100,XXX
2004 F-250 RCLB 6.0 AUTO 4X2 38X,XXX
2005 F-250 RCLB 6.0 AUTO 4x2 36X,XXX
SOLD... 3 RANGERS, 3 F-150s, 3 F-250s, 96 COUGAR 4.6, 99 EXPEDITION 5.4, 65 66 AND 69 MUSTANGS
RE-ASSIGNED... MULTIPLE FORD POLICE INTERCEPTORS
AU7POINT3 is offline
post #3 of 6 Old 09-15-2013, 07:23 PM
Yup shifter wear is the useual culprit but also be shure your fully depressing the brake pedal.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 6 Old 09-24-2013, 08:39 PM
Sno-Mow's Avatar
Check the cable connection to the arm on the drivers side of the tranny. Had similar issue but actually came off while plowing. Not fun crawling under the beast in a foot of snow
2003 F250 6.0l
281,000 miles and counting
EGR Cooler Delete, A1 Studs, 3.5" Down Pipe, 4" Straight Pipe, Turbo Rebuilt, New OE Heads, New HPOP, New Injectors
Blizzard 8611PP
Because you won't push it with a gasser!
Sno-Mow is offline
post #5 of 6 Old 10-27-2013, 05:59 AM Thread Starter
Roadking's Avatar
Update
Installed a new brake switch. Problem has disappeared.
I did disassemble the old switch and all the contacts inside were burnt and toast.
Interesting the shifter has tightened up. How could that be?
Oh well I guess I shouldn't complain. At present all is well.
Thanks all for your input.
1969 MGC
Roadking is offline
post #6 of 6 Old 10-27-2013, 10:13 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Here's a tip for anyone having this problem and thinks they are stranded:
With your foot on the brake so the truck doesn't roll, you can turn your key to the "run" position, then shift into neutral, then start the truck.
Much better than having to call a tow truck!!!
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
