Factory boost gauge not reading right psi - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-14-2013, 09:08 PM Thread Starter
Hello I'm new to the forum but y'all have helped me out. My name is Michael im in the Marine corps and I have a 05' F350 Fx4 dually and my problem is the factory boost gauge isn't reading over 4-5 psi. Is this a gauge problem or a turbo problem the truck runs great and the turbo spools up like a charm. And this truck is my everyday driver please help.
CajunMarine is offline
post #2 of 12 Old 09-14-2013, 09:13 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Most factory boost gauges are reliable and accurate... If your truck has stock tuning. Do you have a monitor of some sorts?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 12 Old 09-14-2013, 09:16 PM Thread Starter
No monitors just stock tuning...but everything I have read the normal boost for the 6.0 is 15+ is this true?
post #4 of 12 Old 09-14-2013, 09:43 PM
Quoted: 8 Post(s)
Stock tuning should see numbers way over that... It's been a few years but I'm pretty sure the stock 6.0 should hit around 26-30 psi. If your turbo can't not hit anywhere close to that I'd say you turbo vanes are sticking. I'd get a monitor quickly, you never know if your oil cooler is clogging with one! When my oil cooler went out my oil temps hit 250-260 and the check engine light never came on. You are driving the truck BLIND! You will have no idea the egr cooler or oil cooler goes out until the head gaskets blow or your engine pumps all the oil into the cooling system.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 12 Old 09-14-2013, 10:01 PM Thread Starter
I'm waiting on my new oil cooler to come in I already have the EGR delete kit but how would I go about cleaning the veins in my turbo if that was the problem?
post #6 of 12 Old 09-14-2013, 10:03 PM
Quoted: 8 Post(s)
You can search Turbo cleaning... Just make sure to click advanced search and choose thread titles only to refine the search!
Turbo Cleaning
Here is another one
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 12 Old 09-14-2013, 10:11 PM Thread Starter
I'll keep you posted on the progress thanks for the help
post #8 of 12 Old 09-14-2013, 10:18 PM
Quoted: 8 Post(s)
No worries man! If money is tight, get a dashboss (if you have an iPhone or iPad) it's only $170.00. If you don't have an iPhone or IPad get the AutoEnginuity... It sells for $225. I prefer the Edge CTS but that's because its all I've ever had
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #9 of 12 Old 09-14-2013, 10:24 PM
Quoted: 8 Post(s)
Here is some links of monitors for ya...
Dassboss
Autoenginuity
Edge Insit
SCT Products
ScanGauge
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #10 of 12 Old 09-14-2013, 10:32 PM
Jack Lester's Avatar
Quoted: 3 Post(s)
Got my Scan GaugeII from bullet proof diesel already programmed for the 6.0 for $170. Money well spent.. Plug in and that's it...
Jack Lester is offline
