Power Steering & Brakes screaming - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-13-2013, 07:48 AM Thread Starter
6.boom's Avatar
This may be dumb but here goes.
Every time I get on my truck hard my power steering pump and brakes scream at me. My brakes vibrate/pulse and hum, and my power steering whines like a baby and gets louder when I step on the accelerator. This ONLY happens when I get on it hard and only lasts for a few minutes. I've asked a few mechanics around here and no one knows what's wrong. My fluids are fine, but this has been getting progressively worse. Maybe I need a new pump and brake thing? Help.
I've got 99 problems and my 6.0L is all of them.
Want to creep? Instagram: lynntaraa
6.boom is offline
post #2 of 6 Old 09-13-2013, 07:56 AM
sargar's Avatar
When you say fluids are fine, are you saying that they (PS fluid) are/is full or new/recent? Power steering fluid degrades over time, especially on a Hydro-Boost vehicle. Ford has had a problem with noisy pumps in the past too. As someone mentioned in the other thread where this was posted, check you belt and tensioner. If that seems good I vote for flushing the power steering fluid and see what happens. A couple of quarts of synthetic fluid is cheaper than throwing parts at it.
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
post #3 of 6 Old 09-13-2013, 07:59 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Im gonna guess you probably need a pump but have you ever done a power steering fld flush?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 6 Old 09-13-2013, 09:36 AM
poorboy1964's Avatar
Quoted: 2 Post(s)
Agreed^^^ it could help to just flush the system 7.3 but the same. if that doesn't help, idler pulls and or pump are what I'd look at next.
Tom
2003 CCSB 4X4 6.0 Born on 5/03 Tuned by Vivian, 4" Turbo Back Exhaust, Edge CTS w/EGT, Coolant filter. ELC. fuel pressure gauge,
2002 SCLB 4X4 7.3 Stock
poorboy1964 is offline
post #5 of 6 Old 09-13-2013, 02:58 PM Thread Starter
6.boom's Avatar
Thank you guys! I just had the engine rebuilt in May so I'd assume it's fresh fluids in there, but you never know. Would the pump itself going bad effect the brakes like it is? An if the pump is going bad...why does it only happen when I stomp on it?
6.boom is offline
post #6 of 6 Old 09-13-2013, 03:07 PM
ZMANN's Avatar
Quoted: 1900 Post(s)
I would definitely check belt tension
fluid condition , specially fill level, belt condition then I would be considering a pump if it was mine
sounds like the pump is screaming and since it's the hydraulic pump for your brakes that is why you feel it there also
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
