need help looking for o rings - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-11-2013, 07:22 PM Thread Starter
does anyone know if there is a part # for the o rings for the two plugs and the oil fitting in pic one ,the plug in the bottom of the oil rail and the plugs on the ends. thanks
or if there is a place that sells them
ID:	166609   Click image for larger version
ID:	166617   Click image for larger version
JayBird94 is offline
post #2 of 2 Old 09-12-2013, 04:56 PM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
Feedback Score: 4 reviews
The 2 plugs in pic 1 can be replaced. Not sure of the part numbers off hand but I do have a pack of the smaller ones at work. If I remember tomorrow I'll look at the bag.
The bigger plug looks like the same ones that block off the icp sensor hole in a left side wavy rail. Probably available from international because LCFs had a problem with this plug but otherwise I'm not sure if it's available or not.
The other 2 there's no way you can get those
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
