05 f550 fuel tank - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-10-2013, 06:58 PM Thread Starter
mikemike0409's Avatar
05 f550 fuel tank
Ok so I think that my fuel tank is rusting on the inside and I was looking around and found this por 15 that is for fuel tank. It is way cheaper then buying a new tank which I know is the best solution to this problem. Anyways has anyone tried this before or know anyone that has?
mikemike0409 is offline
post #2 of 12 Old 11-01-2013, 07:05 PM Thread Starter
UPDATE: I looked into the tank and the inside is peeling off real bad. The pick up tube was filled with the lining of the tank. Everything i read says to just buy a poly tank. Anyone know of a place that sells them at a decent price?
post #3 of 12 Old 11-01-2013, 08:12 PM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
Feedback Score: 4 reviews
Not offhand but I'm sure there are aftermarket options available. Actually I haven't had too many experiences with delaminating fuel tanks. I do know a new Ford tank is still available.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 12 Old 11-02-2013, 11:20 AM
Not meaning to add to your problem but you should be aware that a delaminating tank can cause serious fuel system issues because the laminate not only breaks up in big pieces but also microscopic pieces these can get thru the filters themselves and plug up the actual injectors.
The only real cure is tank replacement and thorough flushing of the lines and remove the end plugs of the fuel rails and injectors and flush ;flush ;flush. Regretably if the injectors can't be cleaned good enough only replacement is a shure fix. Expensive I know.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 12 Old 11-05-2013, 02:04 PM Thread Starter
post #6 of 12 Old 11-05-2013, 05:53 PM
The round part with the little red dot looking thing there is a missing rubber flutter valve like. The red dot is the broke off push pin like part of the valve..
Sorry the best way I can think of to describe it. It will cause suctin problems
post #7 of 12 Old 11-10-2013, 02:38 PM Thread Starter
so what part would i need to fix that piece?
post #8 of 12 Old 11-11-2013, 08:51 AM Thread Starter
Update on the tank problem. Called down to ford to find out what price of a new tank is. Which by the way it sky high as some of you could guess. They gave me a number to a place that will redo the inside of the tank at a price of $300-$400 and it has a lifetime warranty. Anyone have a thought on this pretty sure this is where i going to get this done.
post #9 of 12 Old 11-11-2013, 11:37 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1680 Post(s)
Yes if the shop is as good as the one we use then you should be Good to go. Depending on the type of tank you have I know performance radiator offers a new option for like 250. But I believe that is only a rear mount tank. The saddle tank in the fleet truck is only offered by ford. So your option is a 1k fuel tank or get it resealed.
toren302 is offline
post #10 of 12 Old 11-14-2013, 06:43 AM
Therabbittree's Avatar
https://titanfueltanks.com/
Ford Cab & Chassis Titan Fuel Tank 8020099 $850
I bet you could do a pickup tank swap onto the frame for a lot cheaper..... i wouldn't do a metal tank again if I was you.
Thanks,
Deo
2005 EB Excursion 4x4, Gauges, Scan Gauge II, CCV Vented, Zoodad, EGR deleted, rebuild 6.0L, Studded, BPD HD with Winter setup, BPD 58v FICM, Jesse Warren and Gearhead SCT Tunes, Coolant Bypass Lines, Warren 155/30's, Adrenaline HPOP, Wicked Wheel, Rebuilt VGT, Opened Map Width Groove, Diesel Site Boots, Ported and Deleted Intake Manifold, Regulated Return, Bean's Sump, Aeromotive A1000, 4" Stainless turbo back Magnaflow, Custom Front Bumper, Andy Warren Comp Trans, 09 trans pan and filter
Therabbittree is offline
