Turbo whistle went away - Ford Powerstroke Diesel Forum
post #1 of 18 Old 09-09-2013, 04:30 PM Thread Starter
04F250STROKER's Avatar
I have an 04 f250 with an 03 turbo when I first got the truck it had a really loud whistle and now you can barely hear it the turbo has been cleaned and still didn't help. I am also getting higher EGT's and more smoke than normal. Can someone help me with this problem?
_________________
04 F-250 LARIAT CCSB, banks techni-cooler intercooler system, Bulletproof oil cooler w/filter relocation, Sinister Diesel coolant filter, AEM intake, EGR and cooler delete, ARP head studs, 4" exhaust with performance muffler, sct tuner w/Xtreme street by Eric, 6" lift, 315/75R16 tires
04F250STROKER is offline
post #2 of 18 Old 09-09-2013, 04:39 PM
Snake's Avatar
Quoted: 47 Post(s)
Stuck vanes. Who cleaned it?
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #3 of 18 Old 09-09-2013, 04:45 PM
RedneckYankee's Avatar
Have you checked your EBP sensor and tube?
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #4 of 18 Old 09-09-2013, 04:52 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I asked this very question and nobody believed me.....
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 18 Old 09-09-2013, 05:21 PM Thread Starter
My local mechanic that only works on these trucks.
The ebp sensor and tube was checked and they were cleaned out as well.
_________________
post #6 of 18 Old 09-09-2013, 05:25 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I just asked in another post about the ebp sensor and cleaning it. Thanks for bring this up!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 18 Old 09-09-2013, 06:43 PM Thread Starter
And I have also noticed a lot more turbo surging when it builds boost and let off everyone else that I know that has the 6.0L there's dont do it unless the boost is above 25 and then let off the throttle, mine will do it with 4 psi or higher. What would cause this?
_________________
post #8 of 18 Old 09-09-2013, 09:24 PM
Snake's Avatar
Quoted: 47 Post(s)
If you're confident everything was cleaned well, the VGT actuator, the connector, and the wiring are the next things I'd troubleshoot. Have you hooked the truck to a scanner?
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #9 of 18 Old 09-09-2013, 09:30 PM Thread Starter
I hooked the truck up to a snap on modis scan tool. The only codes that come up is the EGR codes cause there is no EGR in the truck.
_________________
post #10 of 18 Old 09-10-2013, 09:19 AM
Snake's Avatar
Quoted: 47 Post(s)
And you used the Modis to vary the VGT cycle? No codes for that?
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
