egts to high - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-09-2013, 05:11 PM Thread Starter
egts to high
Im posting for a buddy, hes got an 04 6.0 with banks intercooler, banks intake elbow, aem intake, fass fuel. His egys were running normal and they recently started going above 1500 degrees, he thought maybe his turbo was going out so we installed a stage 1 powermax and it still reaches over 1500 degrees but now quicker with the new turbo. Can anyone help me out
05pstroke is offline
post #2 of 5 Old 09-09-2013, 05:50 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Im curious what the guys come up with myself. Ive always thought my egt's were a bit high myself.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 5 Old 09-09-2013, 06:42 PM Thread Starter
I hooked my snap on modis up to it and all the numbers are perfect we just cant figure out why all of a sudden his egts are goin up to 1500 degrees with that stage 1 turbo they should run 1200 max and thats beatin on it
post #4 of 5 Old 09-10-2013, 07:15 PM
I had the same Problem guys from this forum pointed me to find what was causing it for me, I also have the powermax. It was an pre-turbo intake leak and exhaust leak from lack of factory exhaust manifold gaskets on my 03 once I installed exhaust manifold gaskets and fix the loose intake clamp all is good, just something to look into
BP-1 is offline
post #5 of 5 Old 09-11-2013, 05:54 PM
ps_lane01's Avatar
Quoted: 4 Post(s)
Too much fuel, not enough air... Check for exhaust leaks and CAC boot leaks. my truk did the same thing with a small rip in the boot.
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
