6.0 is missing - Ford Powerstroke Diesel Forum
Old 06-04-2008, 01:04 PM
6.0 is missing
i have a 2004 psd 6.0.when i first start up it runs fine.after 40 to 50 miles it wll start to miss,and if i hold the throttle down it fills like its flooding,if it was a gasser you would think the choke was closed.air filter is new,have changed fuel filters two times the last 300 mi.if i let it set for about an hour it runs good for awhile.no lights are on and it is stock
thanks dennis
Old 06-04-2008, 01:53 PM
Clogged EGR?
Old 06-04-2008, 02:17 PM
just cleaned egr
just came in from cleaning it ill know more tomorrow ineed to drive the same place i went today.thanks for your quick reply
Old 06-04-2008, 03:00 PM
you might have a problem with your fueling if it is flooding and missing.... maybe the fuel pump or a bad injector/s. hopefully it may still be under warranty if it is an 04
good luck tho man i'm sure a tech will be able to help you out more
Old 06-04-2008, 03:19 PM
did you check your oil? if its low it acts funny
Old 06-05-2008, 03:35 PM
changed oil
well i changed oil and cleaned egr.today i drove about 20 mi.before it started missing.it seams like it is bumping the limeters,and ones it cools down it runs fine until it reaches the ma heat in the engine. could the thermastat cause this?
