crank no start and frustrated for months!! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-07-2013, 03:48 PM Thread Starter
StandingRisk's Avatar
hey guys, new to the forums here. i kinda poked around and have been researching my problem via google and some forums since it happened. I bought a 2004 F350 6.0 a few months back. ran great, for weeks, then i noticed every now and then ever so slightly it would have a slight power drop when cruising, would happen intermittently at seemingly random times. at around 55 she would do a lil power lunge and shake till i throttle up or down then would stop, it didnt do this all the time but most the time. it was due for an oil change, but only by 100 miles or so(just by going off 3000miles or 3 months) same with fuel filters, they were coming up due. so, i hit a little mud, nothing big, was in and out in a few minutes, wasn't rhomping on it neither. get home. drove to store later in the day. i went out of town for 3 days, come home to my baby not starting. crank no start condition with no relevant codes thrown. new batteries were put in, i primed the fuel pump a few times letting it fully cycle, i returned the sct tuner program back stock, cleared codes, no dice. fuel reset is good, plenty of oil in stick, bro in law hooked up his diagnostic scanner(he is an onsite and fleet mechanic) everything reads proper pressures and voltages, ficm tested good at key on and crank with no drop from 58v(swamps upgrade) even swapped the smaller board in the ficm to test further) fuel pressure is 55-60 i think, and the previous owner upgraded the system to bigger lines and pump a while back. the injectors click for a few seconds when key is on, then they stop. no white smoke or any smoke out the stacks at all. i contacted previous owner (one of my friends) who said he in the last two years has done numerous fixes, new Hpop, icp, crand and cam sensors i believe, egr delete, and a few others i cant remember off the top of my head. like i said, the diag tool shows great numbers and pressures all within spec and still no dice. yes the oil is still fairly clean as well. all fuses are good, and i havent found any bad wires or chafing. any and all help is appreciated. im still waiting on the bro in law to bring his scanner back so we can go further in depth, but so far he said he would "be there tomorrow" going on 3 weeks now. my baby just sitting and im frustrated as all hell. i am mechanically inclined and usually do all my own fixes on all my past or current cars trucks and bikes, this is my first diesel ive ever owned and so far she a real headach. thanks in advance for any and all help.
StandingRisk is offline
post #2 of 8 Old 09-07-2013, 06:45 PM
On the scanner you will have to check for sync and ficm sync. This will confirm a cam or crank sensor to be working correctly. And remember ICP has to reach over 500 psi or the truck won't even attempt to start
Late '04 F350 6.0, studded, 4" exhaust, intake and programmed
ford350f7 is offline
post #3 of 8 Old 09-07-2013, 06:56 PM Thread Starter
ill look into sync when I get the diag scanner here again, but I def have over 500 psi
post #4 of 8 Old 09-10-2013, 09:41 AM
Try hot wire if it even crank, possibly bad powertrain control module or immobliozer system fked up. It could be simply your key.
'07 f350 6.0L Lariat CCSB, 6 speed manual trans
MBRP 4" straight pipe
Stinger 1/0 gauges wires
Dual XS Power D3100 Batteries 2,720cca
ScanguageII
f350deaf is offline
post #5 of 8 Old 09-10-2013, 05:39 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
X2 on checking icp pressure. Do you see oil pressure gauge move while cranking?
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #6 of 8 Old 09-11-2013, 07:36 PM
jtaylor75's Avatar
this is where i would start. i battled a very similar issue. SYNC is where the cam and crank are in sync. This might not change until the engine is running. FICM sync is not only SYNC but is also communications between the PCM and the FICM. this must say yes while cranking and the fuel pulse width must show a number in order to start. PM and ill give you my contact info if you have any more questions
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #7 of 8 Old 09-12-2013, 06:29 PM
bondsman's Avatar
Try disconnecting the icp and go for a start. It could be bad and giving false readings, by unplugging it, the PCM will command the IPR to send pressure to the injectors. If that is not it, try unplugging the exhaust back pressure sensor and go for a start. Finally, unplug the fan clutch connector and go for a start.
Those are just a few quick checks to eliminate faulty sensors.
Get a good scanner on it again and post the codes.
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
post #8 of 8 Old 09-27-2013, 02:21 PM
Dadepowerstroke's Avatar
If you haven't fixed the no start issue by now check out DieselTechRon on YouTube he has a bunch of crank no start troubleshooting videos.
Dadepowerstroke is offline
