6.0 Starts rough and dies - Ford Powerstroke Diesel Forum
post #1 of 13 Old 09-05-2013, 07:54 AM Thread Starter
I changed the oil in my truck bc it had a hard knock, the oil changed fixed that but i started it this morning and it started real rough and it died immediatly, then started it back up and it shot out blue smoke and was idling really bad. and when i pushed on the gas in park there was no acceluration at all and it took about 3 minutes to have any acceluration, help guys please, i just bought this truck and im kinda ****ty
Diesel_trucker is offline
post #2 of 13 Old 09-05-2013, 02:20 PM
Wagsf250's Avatar
Could be possible HPOP going bad. I had the same problem for a while it would start really rough then after a while would just crank and no start
Wagsf250 is offline
post #3 of 13 Old 09-06-2013, 06:01 AM
Could be possible ficm too. Youll have to get the truck on a scanner, preferably for a cold start to watch your ficm voltage and ipr/icp readings
Late '04 F350 6.0, studded, 4" exhaust, intake and programmed
ford350f7 is offline
post #4 of 13 Old 09-06-2013, 06:41 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I would agree that you gotta get a monitor on your truck.They can be found from $150 and up. Right now the truck cannot talk to you to tell you what is wrong. And if it is say a bad ficm you can start eating injectors.
If you are in a cold weather area I would also suggest you run t5 or t6. The cold start will improve 100%. And archoill will also help.
Another suggestion is to go ahead and change out your fuel filters. I know mine looked like the last guy who owned the truck NEVER changed them out. Airfilter, how does that look?
The 6.0 is a picky ole girl that will not put up with us not taking care of them . They want to be pampered but in return they will work when asked and love doing it.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 13 Old 09-07-2013, 08:58 AM Thread Starter
the whole story
Thanks so far guys, ill start from the beginning. I bought it at a andy mohr budget lot with no warrenty, it ran fine for a few days and started getting loufld knock and rough idle when I would start it in the morning, I have always waiting for the glow plug indicator to go off. well Ichanged the oil bc I heard that could cause the hard knock and I dont have hard knock anymore, I changed the fuel filter in the engince compartment but not the one under the truck and after about 4 hours the truck will start fine but it seems overnight I.go to start it and itll die instantly and when I do get it to start it idles rough till warm and I noticed a puff of white smoke coming out the tail pipe. it didnt do of this before I changed my top filter or oil. Helppp please guys
post #6 of 13 Old 09-07-2013, 08:59 AM Thread Starter
its not cold here the coldest it gets is about 60 but when Igo to start it its about 70
post #7 of 13 Old 09-07-2013, 09:09 AM
sargar's Avatar
Did you use Motorcraft filters? I've seen a cheap, parts store oil filter cause a no start before. Check the oil filter cap to make sure it is correct, once again I've seen people reuse a "do not re-use" parts store cap and it holds the drain back valve open.
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
post #8 of 13 Old 09-07-2013, 09:31 AM Thread Starter
reply
I work at advanced auto parts and a I used a puralator pure one oil filter and a puralotor classic fuel filter but I only changed the fuel filter in the engine compartment
post #9 of 13 Old 09-07-2013, 09:35 AM
sargar's Avatar
Not knocking your product, but as previously stated, the 6.0 is a picky girl, pick up some Motorcraft filters.
Being at the parts store, see if any of your wholesale customers will scan it for you (for free) before you spend any more money.
sargar is offline
post #10 of 13 Old 09-07-2013, 09:44 AM Thread Starter
thanks will do, well I have the second filter already should I replace the old one? and I dont have a check engine light or anything just a ****ty start
