Question about crankshaft location when Doing head studs - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-02-2013, 07:21 PM Thread Starter
My ford book says rotate the crankshaft Untill the damper location dowel notch is in the six o'clock position or engine damage can occur .... So my dumb question is since they don't word it better is does this mean pin on the crank at 6o'clock or the notch cut out for the lpop and damper because they are 180 degrees apart lol and just don't want to get it backwards because the book says notch not pin
JBowen747 is offline
post #2 of 5 Old 09-02-2013, 07:23 PM
jtaylor75's Avatar
it means the pin for the damper. some people say it works, some say it dosnt. The biggest thing is to verify that all the push rods are seated in the lifters properly.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #3 of 5 Old 09-02-2013, 07:29 PM Thread Starter
Ok thanks man... I just wanted to double check cuz i have it set right then but i was reading back through and the "notch" word caught my eye and yeah I think I have them all seated good one wasn't at first and I was able to catch it when rocker didn't want to seat right
post #4 of 5 Old 09-02-2013, 07:55 PM
jtaylor75's Avatar
another thing i do is leave the glow plugs out and have a helper turn the motor over by hand while you look at the valve train. After I broke a rocker arm and bent a push rod on my motor, i do that on all the other stud jobs ive done.
06 CCSB FX4 Lariat
Next:
A fuel system
post #5 of 5 Old 09-03-2013, 12:18 PM Thread Starter
Ok I still haven't put my new injectors in yet so I will go ahead and take the glow plugs back out and roll it over by hand
Jeremy
2004 Black&Gray F250 Harley Davidson Crew Cab 4X4
MODS:
6" all spring lift & dual front shocks with 35 NITTO's, MBRP SS cool duals, Harley Orange Ford emblem, ARP studs & OEM gaskets, Adrenaline HPOP, All Ford updates, Owner built fuel system and RR, Owner build trac bars, Warren Diesel 190/75s, MTW hybrid, SCT liverwire ts with IDP tunes & IDP FICM programmer, Sinister Diesel coolant & bypass filter kit, Elite Diesel coolant crossover kit, 07 Harley lights & 6k HID's, Electric Fans
