Transmission Issues - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-02-2013, 04:33 PM Thread Starter
jtaylor75's Avatar
Transmission Issues
I just reinstalled a polished crankshaft it my truck. Drove its almost 5,500 trouble free miles all over the south east. I let my girl friend drive to dairy queen and the truck broke down in the parking lot. Long story short. The truck barley moves when the trans is cold, but once it is hot it dosnt move at all and dosnt go into any gear. I also heard an intermittent rattle after i put the truck together, kind of sounds like the down piper rattling against the firewall, but it all checked out okay. I still had the rattle, the only thing i can think of was the flex plate or torque converter. The tow/ haul light flashes and i pulled two solenoid c codes.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #2 of 3 Old 09-02-2013, 05:16 PM Thread Starter
jtaylor75's Avatar
got a p0761 code and p2702 code.
06 CCSB FX4 Lariat
Next:
A fuel system
post #3 of 3 Old 09-03-2013, 06:53 AM
I believe that is the Coast clutch. Id check like you said the TC to flywheel bolts through the peep hole. Then you could drain and pull the pan and look for clutch materials in the pan and bottom of drain bucket. If there isnt a noticeable amount then it could be the solenoid thats bad. If the solenoid is bad then driving it more on the bad solenoid will only wear out the cluch faster. Also look for any signs of valve body damage or damage to the valve body gasket. Sounds like an issue with fluid pressure, either the solenoid, valve body or your TC went caput.
468 HP & 873 Ft-Lbs
2005 F-350 SRW 4x4 CC Long Bed
SPD tune by Chris @ Truck Source Diesel
ARP Head Studs
3.5" DP to 4" Straight Pipe
Banks High Ram Air Intake
K&N CAI
Edge Evo CTS w/ Backup Camera to monitor
MTS HD Direct Drive Solenoid
Updated:
Standpipe & dummy plugs
Turbo feed & drain tubes
HPOP & IPR screens
Blue Spring
ajfrac is offline
