Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
  #11 (permalink)
Old 06-28-2008, 10:30 AM
krazeehorse krazeehorse is online now
Try running faster and coast back down through the vibration speeds and see if the vibration is the same. You might also try accelerating above the range and pop into neutral and coast back down through and see if there is a difference. If there is I would suspect driveline problems somewhere.
  #12 (permalink)
Old 06-28-2008, 10:36 AM
rickncst rickncst is offline
thanx, will try that to see what happens.
  #13 (permalink)
Old 06-28-2008, 12:49 PM
krazee, tried what you said, put her at about 60mph and let it cost in drive down to 50 (vibration speed) and it did still vibrate. took her back up to 60 and drop her to neutral and coasted back down to 50 and she still vibrates...tried several times and got same results. any other ideas?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
