Fuel Pump Issue - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-01-2013, 06:25 PM Thread Starter
Mud digger's Avatar
Fuel Pump Issue
When I turn my key on to let the glow plugs cycle I can hear my fuel pump but instead of the constant buzz from it, it cuts in and out. I can also see this on my fuel pressure gauge. It doesn't do it all the time, mainly just when started first thing in the morning. It continues to cut in and out when I begin to drive it but levels out after a few minutes. I have a stock pump. Anybody else ever have this issue? Thanks in advance
David
2004 F-250 CCSB 4x4- Sinister Coolant filtration system, CCV reroute, 5" Flo-Pro Exhaust with a 6" MBRP tip, SCT Livewire TS
Mud digger is offline
post #2 of 5 Old 09-02-2013, 11:20 AM Thread Starter
Mud digger's Avatar
I went out this morning and before starting I drained my fuel/water separator. I started the truck and no bouncing of the fuel pressure and no cutting out of the pump. The problem is very intermittent. One thing I did notice is that immediately after starting the FP was 55 and after idling for a minute or so it made it's way up to 60 and leveled out. WTF is going on? Is my pump starting to get weak? It's the original pump and has 135k miles on it.
David
post #3 of 5 Old 09-14-2013, 01:00 PM Thread Starter
Mud digger's Avatar
Anyone have a clue what could be causing this? I can hear the pump cutting out when I cycle the key, and I can see my FP jump up and down. FP levels out after a few minutes of driving.
David
post #4 of 5 Old 09-14-2013, 01:56 PM
Joeshu1000's Avatar
What brand of fuel pressure gauge do you have? Have you turned the truck on and physically felt the pump kick on and off? My guess would be that the pump is on its way out the door.
Joe
2006 F350 XLT CrewCab 4X4
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Rudy's Cold Air Intake
Sinister Coolant Filter
ARP Head Studs W/ OEM Gaskets (Installed myself)
Upgraded Fuel Spring
Updated STC Fitting
Updated Oil Cooler Screen
Updated Dummy Plugs/Standpipes
6.4L Banjo Bolts
PHP Ficm Tuner
1/4 Mile 14.2 @ 93MPH
SCT Custom Tunes: MKM, Looney, SRL, SRLXX, Wildman and SPD w/ Early Lock up
Joeshu1000 is offline
post #5 of 5 Old 09-14-2013, 01:58 PM Thread Starter
Mud digger's Avatar
Isspro EV2 gauge
David
