Getting P0273 & P0282 codes after EGR delete - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-31-2013, 04:09 PM Thread Starter
A few weeks ago I started getting the white smoke from the exhaust. After confirming the failed EGR cooler it sat for a few weeks while I gathered parts and time off.
Fast forward to today. The EGR has been deleted and during the coolant flush cycle (I'm planning on replacing the oil cooler once I finish this Restore & Restore Plus flush) I took it on the highway to get the engine up to temp.
Even while leaving the driveway it seemed to have a bit of hesitation (which at the time I attributed it to air in the fuel system since I also upgraded to the blue spring) which didn't go away once it was on the highway.
I loaded up Torque and it is now listing P0273 & P0282. I think I've got the troubleshooting doc to test the resistance of the injectors and to test the FICM. Yet FICM voltage was showing between 48-49.5.
Anything else I could look at or try? I have reseated the #5 & #8 connectors also.
F350in65202 is offline
post #2 of 3 Old 09-03-2013, 08:53 AM
jtaylor75's Avatar
make sure the connections are still seated properly. sounds like those two injectors arnt plugged in.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #3 of 3 Old 09-05-2013, 06:22 PM Thread Starter
You were correct.
I removed the connectors at the injector to test the resistance. They tested fine, 1.2-1.5 cold.
So I then unbolted the FICM to test continuity and noticed that the #2 connector wasn't fully seated. I reseated it and all is good!
