Test glow plugs at harness? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-31-2013, 04:41 AM Thread Starter
Quoted: 3 Post(s)
I'm chasing down a cold start issue and was thinking that, assuming the harnesses are good, you should be able to test the plugs individually from the GPCM side of the harness to the block. Thoughts?
2005 Excursion Limited 6.0L 2wd
Atlas 40, Bulletproof EGR cooler, coolant filter, 6.4L banjos, Cat coolant, Gogo direct solenoid, 7.3 fan clutch. Otherwise, all stock.
bigric is offline
post #2 of 4 Old 08-31-2013, 02:13 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
yes you can. I find it easier to resistance test the plugs where the glow plug harness connects into the main engine harness. Good glow plug resistance is low, 1-2 ohms typically
BUT if you're not throwing any glow plug DTCs then you probably are not going to find anything by testing resistance. You would need to test the draw of a bank of glowplugs with an inductive ammeter to really know anything.
I will say that usually cold start problems are due to a failing FICM or sludged up injectors.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 4 Old 08-31-2013, 08:34 PM Thread Starter
Quoted: 3 Post(s)
Thanks; I needed an excuse to upgrade my DVM anyway.
As a little background, I've got a recent ficmrepair unit, solid hpo, and good batteries. I'd been tracking hpo and FICM voltage during cold cranking but noticed for the first time this morning that cranking speed was ~110 rpm during several failed attempts. My starter went out this afternoon (although in a different failure mode), so it'll be interesting to see how it behaves now. The new starter is already much more quiet...
bigric is offline
post #4 of 4 Old 09-01-2013, 06:52 AM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
yeah good cranking speed varies but is definitely more than that. I've seen some trucks with all conditions right have cranking speed near 200 RPM.
-Matt
2015 F-250 XLT 6.7L
