04 6.0 issues - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-28-2013, 06:53 PM Thread Starter
04 6.0 issues
Hey everyone, new on the site and looking to see if I can get some help regarding issues on my truck. The truck is a late build 04 f250 6.0 with just an egr delete and powermax turbo. Well, I had finished installing the egr delete and new oil cooler after the egr cooler failed. The truck ran great for a couple weeks until one day it felt like the fuel was cutting out and the truck stalled. It started right back up and I made it a little further up the road till it stalled again. Got the truck home long story short the truck will start but idles rough and stalls. Sometimes it stalls in park at idle sometimes I can take the rpms up and it will stall coming down. The truck will have no starts as it heats up but eventually starts back up. Either way the truck is not drivable. the ficm is putting out 48 volts. I replaced the icp sensor, checked wiring to sensors, cleaned ebp sensor, fuel pressure read 100% on snapon scanner, no codes except for cylinders 2 and 4 glow plug circuit and 1 memory code for the crank position sensor which I assume was a previous fix. The truck has just over 80,000 miles and just started having this issue. Any ideas appreciated sorry for the long intro. Im sure theres other details ill remember as the thread progesses. Thanks
04strokeorbroke is offline
post #2 of 3 Old 08-29-2013, 01:52 PM
jtaylor75's Avatar
There is no fuel pressure sensor on the 6.0. You have to use the test port on the secondary fuel filter housing to get a reading in PSI. The scanner is probably telling you if the fuel pump in on (100%) or not (0%). If you have not installed a blue fuel pressure spring and changed your fuel filters i would start there. Also check your actual and desired ICP numbers on the scanner and get back to us.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #3 of 3 Old 08-29-2013, 05:25 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
ipr valve has trash in it
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
