Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
  #11 (permalink)
Old 05-27-2008, 12:15 PM
david5303 david5303 is offline
Kinda of looking for an answer on this myself. I noticed this the most when i am towing and have sustained EGT's of over 1200
  #12 (permalink)
Old 05-30-2008, 07:19 PM
DuraWhat? DuraWhat? is offline
It would make sense I guess the things been going out about every 30k miles so Its about due Bump Bump
  #13 (permalink)
Old 06-01-2008, 09:54 AM
Is your truck throwing codes? Mine is PO 299 which I cant find any solid info on and also PO 282 which is Cylinder 8 injector Curcit Low. I googled the crap out of the 299 and im not comming up with much at all. Any Ideas
  #14 (permalink)
Old 06-26-2008, 04:29 PM
svenny14 svenny14 is offline
bump............
  #15 (permalink)
Old 06-27-2008, 02:50 PM
97 golden stroker 97 golden stroker is offline
ok im a gm master tech and i just looked it up and found that that is a slow leak in the boost side of your intake. it should be the same for ford most of the time they are. but i could be rong.
  #16 (permalink)
Old 06-27-2008, 02:52 PM
Turbo Charge Air Cooler Hose Oil Seepage, Or Dislodged On Acceleration
that is from all data on ford.
  #17 (permalink)
Old 07-02-2008, 04:30 PM
So basicaly look for a leak in one of the silicon boots? Turbo Charge Air Cooler Hose Oil Seepage? Thats the small metal tube running into the turbo right?
  #18 (permalink)
Old 07-21-2008, 04:02 PM
Did you ever figure yours out?
  #19 (permalink)
Old 08-24-2008, 04:54 PM
hardcorediesel hardcorediesel is offline
Send a message via AIM to hardcorediesel
no boost no power
Iam havin same problem. my 6.0 ran fine and i was out of town for 4 days..came back and few miles later it would dog down.. At first, it dogs down at 1100 1400 rpm. and ran fine after that (on the way home when i got back in town). now it bogs down from 1100 and up and Zero boost (got worse) like it was starving for fuel, so i changed filters. same results. idles normal but thats it. any suggestions...?
  #20 (permalink)
Old 10-05-2008, 07:56 PM
Big Mule Big Mule is offline
I had the same problem today. I had just got back from a 300 mile round trip pulling my 5th wheel (truck ran great). Dropped my 5th wheel off at my storage, and when I got on the road I noticed my speedometer was not working. I just blew it off but when I started up a descent grade I had no boost and very little acceleration so I started to pull over and then I heard a loud click and all of a sudden I had full power and my speedometer was working again. I drove another 30 miles after that with out any problems. It makes me think it is an electrical problem. My whole EGR system is gone so that is out the window for me.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
