Rough idle with weird turbo sound - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-26-2013, 07:46 PM Thread Starter
I have 05 with edge juice. The other day I notice when idling rpms jump from 500 to 1100. It sounds like someone is barely tapping on the accelerator. Its down this as well sitting at a red light but at the red light it has jerked like it was wanting to go.
The other issue is with the turbo. I have 5 in straight pipe on the truck. When the truck is idling or at a red light the turbo sounds like it kicks down with the truck making a deep rumble (the sound is like a truck downshifting deep rumble) through the exhaust.
I have just replaced the egr and ficm less then 3000 miles ago. Can suggestions?
zgbishop is offline
post #2 of 3 Old 08-27-2013, 03:33 PM
Quoted: 253 Post(s)
it's only a very wild guess, but for some reason I'm thinking a bad electric harness.
2005 F350 srw Crewcab lariat. 6.0 diesel
nitrogen is online now
post #3 of 3 Old 09-24-2013, 08:15 PM
Sno-Mow's Avatar
Check/clean air filter and MAF sensor. Had same issue and cleared it right up.
2003 F250 6.0l
281,000 miles and counting
EGR Cooler Delete, A1 Studs, 3.5" Down Pipe, 4" Straight Pipe, Turbo Rebuilt, New OE Heads, New HPOP, New Injectors
Blizzard 8611PP
Because you won't push it with a gasser!
Sno-Mow is offline
