2005 auto locking/locking hub question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-26-2013, 02:58 PM Thread Starter
Skip Sackett's Avatar
Question 2005 auto locking/locking hub question
I have hubs on my '05 F250 that say "Auto" and "Lock". My right side allowed the axle to turn when it was in "Auto". I took it apart, cleans and lightly greases all of the splines and now, it works but......
How much grease should be used? Should I pack it full?
I have done a search hear and on YouTube for some answered but my hubs don't seem to be covered anywhere.
A little help folks!
Thanks!
Mods as of 4/3/2015
2005 F250 SC SB 4WD & 2003 Excursion 4WDD
ARP Studs
BIGGDOGG heads
MISHIMOTO welded aluminum radiator
EGR delete
Blue Spring Modification (Personally Installed!)
Edge Evolution (PHP Gryphon with 4 tunes)
Atlas 40 FICM tune
HPOP upgrade
Coolant bypass from #7 & #8 to thermostat housing.
Coolant Bypass Filter
Skip Sackett is offline
post #2 of 7 Old 08-26-2013, 08:03 PM
Ur post is kinda confusing, can you clarify your question?
The locking hubs dont need a lot of grease, just enough to lightly coat, if thats what ur asking. There are no bearings on the outside so alot of grease does no good
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
post #3 of 7 Old 08-26-2013, 08:05 PM
Read it again and again and i am understanding now. Sorry, your rt axle is spinning when in 2wd and hubs in auto postion???
gblauf is offline
post #4 of 7 Old 08-27-2013, 05:31 AM
Quoted: 57 Post(s)
Its likely rotating under the drag of the gear train, not moving under power. Very common.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #5 of 7 Old 08-27-2013, 04:37 PM
Quoted: 236 Post(s)
there is a tiny needle bearing, the shift collar slides back and forth inside this bearing. that is the only part that really needs grease, IIRC. I'd tend to use a thin soft grease, as too thick, or too much when it is cold and it will tend to much the sliding collar sticky. the spines of the shift collar definitely want a soft cold weather compatible grease
2005 F350 srw Crewcab lariat. 6.0 diesel aka Sherman
Carstairs Alberta
nitrogen is offline
post #6 of 7 Old 09-07-2013, 08:35 AM
soccerman's Avatar
On the same hub topic, I noticed that my front hubs are in the lock position instead of auto. Is that OK (Pro and Cons)? or should I put it in auto?
I want to make sure everything is well lubed that needs to be lubed.
Thanks
2006 F350 Lariat
TowBoss Package
Front & Rear Camera
High Idle Mod
Rear Flood Lights
58V Swamps FICM
Remote Start
Straight Pipe
HID Head Lights
BD Heavy Duty EGR Cooler
Blue Spring Upgrade
STC fitting Upgrade
New IPR
Standpipes/Dummy Plugs
Lockpick
soccerman is offline
post #7 of 7 Old 09-07-2013, 01:42 PM
if you leave them in lock it will wear out the outer locking hubs they are not meant to travel at freeway speeds I have replaced so many at work due to that. Once they are put back in auto they will not unlock thats how you know they are toast.
PowerstrokeAaron is offline
