Black smoke BILLOWING and a knocking on the passanger side - Ford Powerstroke Diesel Forum
post #1 of 22 Old 08-23-2013, 11:01 AM Thread Starter
Red face Black smoke BILLOWING and a knocking on the passanger side
Hey guys! I have a 2003 F250 King Ranch 6.0L. All stock except my intake filter. In March I did the normal maintenance (oil change, filters, radiator flush and coolant change) and also changed the CPS. Rev X in the oil and Lucas in the fuel. Yesterday it started smoking black pretty bad even at an idle. Today it smoked horrid and is now making a knocking sound on the passenger side. Pretty sure I got some bad diesel. I only go to a few stations but had to stop at this particular one that is known for bad diesel. I am not throwing any codes or indication lights. All my gauges are staying where they should. The smoke smells heavy in diesel. Any ideas?
Thanks in advance from a girl who loves her truck!
Goebellove is offline
post #2 of 22 Old 08-23-2013, 11:50 AM
Quoted: 763 Post(s)
Sounds like an injector just went south.
Corey@CNCFAB is offline
post #3 of 22 Old 08-23-2013, 11:54 AM Thread Starter
Any ideas on how to tell which one it could be? It's coming from the passenger side. I am guessing maybe #5 but can't be sure.
post #4 of 22 Old 08-23-2013, 12:00 PM
Quoted: 763 Post(s)
The knock or black smoke on the passenger side. Hopefully just the knock.
To verify, have it checked at a shop that is reputable for the 6.0L.
post #5 of 22 Old 08-23-2013, 12:05 PM Thread Starter
I live in the middle of a pot hole in New Mexico. Only place for my truck is the stealership and they messed it up more than anything last time. I have been doing all the repairs myself.
post #6 of 22 Old 08-23-2013, 12:21 PM
Quoted: 763 Post(s)
BTW, welcome to the org.
I don't doubt you one bit about the "stealerships"
Best thing for you can do for yourself is invest in AutoEnginuity software for a laptop. Truly a thing of beauty to troubleshoot our trucks
post #7 of 22 Old 08-23-2013, 12:23 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
You need to get access to a scan tool that can do a buzz test. Auto Engenuity is the most common one, a bit expensive but is worth it because it can be used for several other tests and pulling codes.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #8 of 22 Old 08-23-2013, 12:28 PM
usnavyad's Avatar
Feedback Score: 3 reviews
Agree a buzz test then a cyl contribution test is needed welcome btw
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #9 of 22 Old 08-23-2013, 12:56 PM Thread Starter
Any ideas if you can rent a scanner? Hubby is military and we are not rich! LoL Hoping to have it all done this weekend. That is the best case scenario!
post #10 of 22 Old 08-23-2013, 12:59 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
There a couple 6.0L guys here from NM maybe they can chime in and lend a hand?
Welcome to the .org BTW
2000-7.3L is offline
