HARD START, Only starts on second crank....?????? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-23-2013, 09:56 AM Thread Starter
This is a wierd issue, but i have long cranking hot or cold. Here is what i have discovered. If you crank it once, it will never start, even cranking for 15 secs. As soon as you try a second time, it fires right up. So today, i tried just blipping the starter real quick, and then doing it agian, and she fires up within 2 secs of cranking the 2nd time.
What in the world could cause this??? I am guessing a electrical issue. Ficm is good, batteries are good. New icp sensor, ipr sensor, new fuel filters, new rotella t6. None of these have coincided with this issue. Just plain maintiance, other than the sensors.
2006 f350, 114k
Thanks gb
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
post #2 of 4 Old 08-27-2013, 05:06 PM
Quoted: 223 Post(s)
bump, got me stumped.
2005 F350 srw Crewcab lariat. 6.0 diesel aka Sherman
Carstairs Alberta
nitrogen is offline
post #3 of 4 Old 09-08-2013, 09:30 PM
drivininidaho's Avatar
Quoted: 67 Post(s)
im kinda going through the same thing. but even on second or third cranks i still have issues. but if i allow the pump and key to sit in the "on" position and then try it seems to start a little bit better. but im interested to see outcome...
Lyndel
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #4 of 4 Old 09-08-2013, 10:20 PM
sargar's Avatar
Do you monitor fuel pressure? I wonder what it looks like during "no start"?
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
