Engine dies randomly - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-22-2013, 08:03 PM Thread Starter
2004 6.0 cc drw 4wd. Just randomly while driving sometimes the water in fuel light and the wait to start lights come on and the engine shuts off. I can let off the throttle and wait til the lights go off and ease into it and it will go on but if I hold the throttle it will just start bucking. Sometimes when u step back on it, it will shut down again. I have found some posts other places about this same problem but there was no resolution that I could find. It seems like an electrical problem to me. Anybody got a possible solution?
dlturner00 is offline
post #2 of 6 Old 08-26-2013, 06:25 PM Thread Starter
Ok so no replies. Did some more research and found info on harness chafing. I decided to go that route after seeing my exact symptoms. Cranked it up, climbed up where I could reach it and started wiggling the FICM harness and BINGO! Did exactly what it has been doing while driving. Now just getting in there to actually fix it.
post #3 of 6 Old 08-27-2013, 04:39 PM
Quoted: 223 Post(s)
glad you were able to identify the issue. now on to finding exactly where the break is, and fixing it so it doesn't happen again. wish you well
2005 F350 srw Crewcab lariat. 6.0 diesel aka Sherman
Carstairs Alberta
nitrogen is offline
post #4 of 6 Old 08-30-2013, 10:55 AM Thread Starter
Well I think I found it. Shorted wire on #1 injector. Taped it up real good and put a piece of rubber under the spot. It was rubbing on a bolt head. Taped some other slightly chafed spots at the FICM but didn't see any bare wires. Put some rubber under those spots as well. Drove it several miles, starting & stopping a lot. Hasn't done it again. Crossing my fingers! I'll try to post pics.
post #5 of 6 Old 08-30-2013, 02:33 PM Thread Starter
First pic is intake bolt wire was rubbing on. Second one shows the bare spot near the injector plug.
post #6 of 6 Old 08-30-2013, 04:18 PM
ps_lane01's Avatar
Quoted: 2 Post(s)
Good find
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
