Belt Tension - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-21-2013, 07:32 PM Thread Starter
Belt Tension
Alright, I've read where you pull up on the belt and have someone flip the lock on the tensioner (except for the one dude that said he pulled the belt up with left hand and flicked the tab with his right). How the heck y'all doing this? I've read standing on the engine, but there is no room - are you taking the hood off?
Any ideas would help as I really need to get the alternator changed - only putting out 11.8 volts, and of course getting a wrench on the tensioner is like...........impossible.
David
2003 F350 4x4 CC Lariat 6.0
dsprint2000 is offline
post #2 of 12 Old 08-21-2013, 07:37 PM
ZMANN's Avatar
Quoted: 1469 Post(s)
i stand on the pass side tire cause mines lifted and pull the belt flip down the retention no removal of anything
you have to be a little large for the leverage or have some upper body strength
otherwise just use a 1/2 breaker bar and the square recess
We Miss you Ronnie
ZMANN is offline
post #3 of 12 Old 08-21-2013, 07:38 PM
ZMANN's Avatar
I have heard of loosening the alt and tipping it out of a fully tensioned belt but I have not tried that
We Miss you Ronnie
ZMANN is offline
post #4 of 12 Old 08-21-2013, 07:42 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Im a pretty big boy (6'4" 213lbs) and I will tell you there is room. It aint comfy but you can do it.
What I do is throw 2 very thick worn out winter jackets over the motor. I crawl right up and in there. I then grab the belt and heeveho and have who ever is around flip the trap door. But ya your gonna have to PULL!!!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 12 Old 08-21-2013, 07:47 PM
ZMANN's Avatar
i have the same height but 40 lbs on you maybe weight is the key ? LOL
i don't pull up on mine i pull out toward the pass side and no one is ever around so flippin the retainer is mine also
We Miss you Ronnie
ZMANN is offline
post #6 of 12 Old 08-21-2013, 07:49 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Hmmm towards the passenger side......Ill give that a try.
Ive had my kids up there and they weigh around 50 lbs and they still complain!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 12 Old 08-21-2013, 08:36 PM
Yea ya gotta be a real grown up boy to use the belt pull trick. I had a guy in the stall next to me that could just standing on the floor reach over pull the belt with one hand and set the latch with the other. Only guy I ever saw could do that.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #8 of 12 Old 08-22-2013, 05:34 AM Thread Starter
I'll give the passenger side trick a shot......not a lot of room for my 270lb svelte figure up there. I climbed in but just could not find a good angle to pull.
Guess I better go buy some Wheaties.....
David
post #9 of 12 Old 08-22-2013, 06:13 AM
powerstrokecrzy's Avatar
Quoted: 241 Post(s)
I stand on the passenger side, pull the belt toward me with one hand, flip the latch with the other. Have always read on here how hard a time people have with it but I've never had a problem.
On a different subject, changing the belt they say can be a real pain but I did it in less than 10 minutes without removing anything and yes the stator is still there.
GOOD LUCK:thumbup:
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is online now
post #10 of 12 Old 08-22-2013, 07:03 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
GOOD LUCK:thumbup:
You dont have one large eyebrow by any chance????
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
