4 wheel drive will not disengage electronically or manually??? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-18-2008, 11:29 AM Thread Starter
Question 4 wheel drive will not disengage electronically or manually???
Launched the boat yesterday evening... placed truck in 4 high to tow the rig out of the water on the incline and muddy ramp. Returned truck to 2 wheel drive and drove 10 miles back to the house with no problem. Let truck sit about one hour and jumped back in to find that the truck was in 4 wheel low on the dash with 4 wheel drive indicator lit up. The on dash selector switch was in the 2 wheel drive position and the hubs were in the automatic position.
any help, can not get truck out of 4 wheel low!
Tried everything even disconnected battery, to no avail.
'04 F250 CC 4X4
p-stroke250 is offline
post #2 of 9 Old 05-18-2008, 11:31 AM
sldghamr's Avatar
i thought Ford 4x4's were setup so that you need to back up a few feet in order to disengage the xfer case??
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #3 of 9 Old 05-18-2008, 11:33 AM
somebodyelse5's Avatar
Try that then see what happens. Or try manually locking the hubs and then unlocking them. Let us know!
Good luck!
Joe
White 2002 F350 7.3
Pinch weld covers
Amp steps
KMC XD Ambush
BFG AT's
aFe stage II with pro guard 7
Edge Juice w/ Attitude
Rockford, pioneer, kicker, polk
5" Turbo back from farmboy
Foil delete
08 vent badges
CB
Originally Posted by AvroAero View Post
If you can cut a massive hole in your own fender, I'd say your the DIYOTM. I'd be ****ting myself that something would go wrong.
made my day
somebodyelse5 is offline
post #4 of 9 Old 05-18-2008, 11:34 AM Thread Starter
I drove it home fully disengaged with the selector switch in 2 wd, it electronically locked itself in 4 wheel low with the selector switch in 2wd. Doesn't make sense... a sensor must have failed, but which one ???
post #5 of 9 Old 05-18-2008, 11:35 AM Thread Starter
Good luck!
locked, unlocked, reverse, forward and alternated the on dash selector switch. Firmly in 4 wheel low and will not come out, no on dash indications and or codes...
post #6 of 9 Old 05-18-2008, 11:43 AM
So the truck does not "think" its in 4wd but it IS? take it to ford maybe?
Joe
White 2002 F350 7.3
Pinch weld covers
Amp steps
KMC XD Ambush
BFG AT's
Foil delete
08 vent badges
CB
made my day
post #7 of 9 Old 05-18-2008, 11:49 AM Thread Starter
The dash is lit up 4wd low / 4wd engaged. both lights are lit up and the truck is literally in 4wd low, unable to drive above 25-30 mph...
post #8 of 9 Old 05-18-2008, 02:45 PM
jello's Avatar
Look in your manual for the location of the 4 wheel drive motor relays. I think they are under the hood by the left fender/firewall area. Replace them they may have moisture in them. They're cheap regular Bosch type relays. If that doesn't work it's atrip to the shop.
You can unplug the wiring from the shift motor on the transfercase, unbolt the motor, shift case manually, and put motor back on but don't plug the wiring back in. That should get you in 2HI for now.
2003 King Ranch 6.0
MBRP 4" turbo back no cat
SCT by gogodiesel(direct injection performance)
jello is offline
post #9 of 9 Old 05-18-2008, 02:59 PM
fordmugg's Avatar
WOW thats funny because i thought you had to be in neutral to go into 4wheel low? and have to be in neutral to get it out
my name is jeff but my friends call me.........jeff
2003 f-250 6.0 lariat, crew cab, long bed,fx4
Autometer guages
Z plate Zoodad
4inch turbo back
s&b intake
Pro comp
8.5 inch lift
Dual shocks
toyo 37's
stereo System
100% awesome
fordmugg is offline
