6.0 lagging bad! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-21-2013, 09:27 AM Thread Starter
6.0 lagging bad!
03 6.0 turbo lag
I have a 2003 6.0 and have recently started having trouble with laggy response on my throttle. When i start the truck up and take it down the road i can sometimes have my foot up to 75% into the petal before it will decide to take off properly, the truck will be accelerating very slow then out of nowhere take off like a bat out of hell. This is a major problem when i try to cross highways or merge onto a road. Can someone please try to point me to what the problem could be, i would prefer not getting killed by oncoming traffic.
csingleton6.0 is offline
post #2 of 9 Old 08-21-2013, 07:35 PM
Have the same problem sometimes - seems the turbo isn't spooling up, but if I let off for a second then romp on it, it goes. No answer here, but will watch what is said....
David
2003 F350 4x4 CC Lariat 6.0
dsprint2000 is offline
post #3 of 9 Old 08-21-2013, 08:54 PM
your not driving the truck right you need to ease into the stump truck arent like hot rods were you stump and go
christdquan87 is offline
post #4 of 9 Old 08-22-2013, 08:18 AM Thread Starter
It's not like I just stomp on it to go. I will drive it regular and it will not go anywhere. I think my turbo is shot, it won't start building boost until I am at about 2500 rpm going like 40. Then it'll take off, chirp my tires are roll coal.
post #5 of 9 Old 08-22-2013, 09:03 AM
So I had the same problem two weeks ago with my 04. Boost on my gauge was showing a quick increase, but the truck really lagged. Took it to a mechanic. We pulled the turbo. The actuator ring was rusted in place. I mean really rusted. Darn thing would not move. This caused the veins to stay in the closed position. So, we put a new ring and actuator in it, and low and behold, power again.
However, let me say this. At a dead stop, if I stomp on it, the truck takes about a second to start moving, and about 2 seconds until it really starts moving. But then, it just rockets across the intersection. I have to plan for that delay though. Kinda use to it now. It has been like that since day one.
RJD2516 is offline
post #6 of 9 Old 08-22-2013, 09:09 AM
Lilfarmrboy's Avatar
I was going to say you might have a turbo boost leak but if it builds up after a few seconds then it sounds like its the turbo. If you have the OEM it is known to have the variable vanes stick. Could be something major or it might just need a good cleaning. When you get it fixed at least once a week take that truck down a back road and really stomp on her to get that trash cleaned out of the turbo.
Lilfarmrboy is offline
post #7 of 9 Old 08-22-2013, 09:16 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
Originally Posted by csingleton6.0 View Post
03 6.0 turbo lag
Does it smoke the whole time?
Best way to fix this is to flog the hell out of it and work that turbo untill it unsticks. If that doenst work, pull it and clean the turbo real good with a small wire wheel and use antisieze on the ring and viens and put it back together. If any oil rings are leaking, a rebuild parts kit can be bought from Garrett for $50
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #8 of 9 Old 08-22-2013, 09:23 AM
Clay, I love that pic of Sam Elliott! Lot of truth with that statement
post #9 of 9 Old 08-22-2013, 08:21 PM Thread Starter
Pulled the turbo, it was caked with soot, cleaned it up and the whole internal side that attaches to the exhaust was pitted with rust. The veins look shot and torn up. Looks like I'll have to replace most of this thing.
Tags
6.0 problems , lag , throttle lag , throttle response , turbo 6.0
