Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
  #21 (permalink)
Old 12-21-2006, 02:42 PM
ensiv ensiv is offline
Send a message via AIM to ensiv Send a message via Yahoo to ensiv
I spoke to the trailer manufacturer today and found that the problem is the the TBC that Ford built is garbage. The same controllers that control electric brakes also control electric over hydraulic brake systems but for some reason the parameters that Ford has utilized in there controller will not function.
The good news is that I can purchase the same harness plug on the back of the Ford TBC and solder it up to the aftermarket controller. I can then disconnect the onboard TBC and plug in the aftermarket without cutting any wires under the dash so that when I sell this truck in four years I can plug it all back together.
Now maybe everyone will understand my frustration with this controller. There should be no reason at all for it not working.
  #22 (permalink)
Old 12-21-2006, 03:17 PM
WD40 WD40 is offline
TBC that Ford built is garbage. Yep, Right. I wouldn't take for mine. I have tried to post what you need to do. I don't know why you posted here in the first place.
  #23 (permalink)
Old 01-14-2007, 09:58 AM
Hayman Hayman is offline
Lose wire
Mine 2006 was doing the same thing on my goose neck every time i hit the brakes i Finlay found it in the plug of the trailer one of the wire was grounding out.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
