Steering / Brake troubles - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-20-2013, 09:53 AM Thread Starter
Quoted: 4 Post(s)
On the way home Saturday, the steering started to get jerky (as if PS was going out) and then the as I applied the brakes, I got a loud moaning sound.
After I got home and the truck sat, the PS fluid was very low (more than 1 qt low)
Not knowing any better, I topped it off to the full level with POWER STEERING FLUID. After reading on here, It seems that was a mistake. Does the 6.0 really use ATF as the Brake / PS fluid ?
I have not cranked the truck since, so *maybe* I can siphon most back out and refill with ATF?
Whats my best course of action? Any advice?
2005 6.0 F-250 - Upgraded FICM by FICMRepair.com - 4" MBRP Exhaust - PMM Coolant Filtration System - Zoodad Mod - CCV Mod
Chris4x4gill2 is offline
post #2 of 12 Old 08-20-2013, 10:59 AM
Quoted: 725 Post(s)
Siphon what you can and do a flush.
Corey@CNCFAB is offline
post #3 of 12 Old 08-20-2013, 11:15 AM Thread Starter
Quoted: 4 Post(s)
OK. That will be step one. But now i need to figure out why I had the problem in the first place.
Whats a common failure point in the system? Any known problem areas I need ot check first?
post #4 of 12 Old 08-22-2013, 11:25 AM Thread Starter
Quoted: 4 Post(s)
Flushed the system using almost 5 qts of ATF. When I got done there is a huge puddle of fluid under the truck. It was getting dark so I couldnt determine where it came from. Seemed to be from the driver side near front of the engine somewhere.
post #5 of 12 Old 08-22-2013, 11:42 AM
ThomasvillePavers's Avatar
It's common for the pressure line fittings where the hose attaches to the pump to fail over time, if it appears to be leaking from the fitting you must replace the entire pressure line as there is no internal seal there. If the truck is leaking that rapidly then pin pointing the leak should not be hard.
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #6 of 12 Old 08-22-2013, 11:45 AM
Quoted: 725 Post(s)
Did you do the flush with the engine running? If not that's why you had a big puddle under the truck
post #7 of 12 Old 08-22-2013, 11:45 AM Thread Starter
Quoted: 4 Post(s)
yes, flushed with engine running.
post #8 of 12 Old 08-22-2013, 11:46 AM Thread Starter
Quoted: 4 Post(s)
How hard is the pressure line to replace? looks to be a pain to get to.
post #9 of 12 Old 08-22-2013, 11:58 AM
Quoted: 725 Post(s)
https://www.youtube.com/watch?v=0fVX...e_gdata_player
Did you do it this way? If so then you may have a bad hose under there.
post #10 of 12 Old 08-22-2013, 12:10 PM Thread Starter
Quoted: 4 Post(s)
Yes. That is how I did it.
I am hoping its a hose, but I couldnt pinpoint the leak. I'm going to try again tonight, but I will probably have to take it to the shop and let them do the work. I just dont have time for the next several weeks due to work.
