Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 05-16-2008, 06:40 PM
GPATTERSON319 GPATTERSON319 is offline
Unhappy 6.0 BLOWBY HELP????
I HAVE A 2005 F250 THAT WENT TO THE DEALER TODAY FOR A CHECKUP. THEY TOLD ME THAT THE ENGINE MEASURED 3 BARS OF BLOWBY (WHAT DOES THIS MEAN?) THE ENGINE CURRENTLY HAS 124K AND FEELS AS STRONG AS EVER. DO YOU THINK THE ENGINE BLOWBY IS SOMETHING TO WORRY ABOUT?
Old 05-16-2008, 06:44 PM
bigcountrysg bigcountrysg is offline
Countryboy Mechanic
It means it blowsby 3 bars and stops at the 4th one.
No honestly I have no clue and I have never heard of blow by being rated in bars.
Old 05-16-2008, 06:53 PM
cob32187 cob32187 is offline
Send a message via AIM to cob32187 Send a message via Yahoo to cob32187
One bar = atmospheric pressure, so that would mean that your blowby is 3x the atmospheric pressure. 1 bar = 14.5038 psi, therefore 3 bars would equal approx. 43.5114 psi. That of course would be absolute pressure, which is normally not used in these applications. The way its normally measured is pressure above atmospheric pressure, therefore it would be 3 bars above atmospheric pressure, 4 bars = 58.0152 psi. There is no way in hell you have enough blowby to have that much pressure in the crank case.
I could be way off though, i just try to be smart
Old 05-16-2008, 06:54 PM
Diesel Freak Diesel Freak is offline
Rice Hunter
Blowby tells me that compression is loss either by piston rings or valves.
Maybe even head gaskets.
Old 05-17-2008, 03:52 AM
THANKS FOR THE RESPONSES. THEY REPLACED THE HEAD GASKETS @ 54K MILES. WILL THERE BE A NOTICEABLE DIFFERENCE IN POWER LOOS WITH THIS MUCH BLOWBY BECAUSE I NOTICE NONE. HOW WORRIED SHOULD I BE AT THIS POINT?
Old 05-17-2008, 04:50 AM
Evil Eye Evil Eye is offline
Slacker
Most folks don't know they have blown head gaskets due to power loss; they notice the coolant puking and the high engine temps... You can continue to drive with blown HG's, although you should take it easy. BTW, the heads were prone to warpage (depending on how bad the gaskets and how hot the block was, and they recently updated the spec to .002. Do you know if they mic'd the heads and what they were at the time the HG's were replaced? It sounds like one or both of your heads are warped or your HG's are bad (again). That would be a pricey fix without a drivetrain warranty. Let us know what they say...
Old 05-17-2008, 04:51 AM
Rice Hunter
I don't think so! Did they replace with studs or bolts? Ford changed the torque specs on bolts but I still do not trust the bolts much. JMO Do you have a chip or programmer??
Old 05-17-2008, 05:46 AM
I RECENTLY PURCHASED THIS TRUCK WITH THE AGREEMENT THAT THE TRUCK QUALIFIES FOR THE FORD EXTENDED WARRANTY PROGRAM. I CONTACTED THE ORIGINAL OWNER OF THE TRUCK AND HE STATED THAT FORD REPLACED THE HEAD GASKETS IN THE 50K RANGE. HE ALSO GAVE ME A SCT PROGRAMMER WITH CUSTOME TUNES. K&N INTAKE AND MAGANOFLOW 4" EXHAUST. I HAVE NOTICED THAT COOLANT BLOWS OUT OF THE COOLANT CAP ONLY WHEN IT IS UNDER LOAD. THE TRUCK NEVER RUNS HOT THOUGH. HELP, HELP, HELP....
Old 05-18-2008, 05:15 AM
I WENT TO THE ORIGINAL SELLING DEALER AND THE SERVICE MANAGER THERE PRINTED OUT A COMPLTE SERVICE HISTORY ON THE TRUCK. IT APPEARS THAT THE HEADS WERE REPLACED @ 52K MILES. WHAT KIND OF EXPENSE WILL NEW HEADS INSTALLED BE?
Old 05-18-2008, 05:39 AM
Slacker
The tech will have to pull your engine to install new heads. It varies, but you are looking at upwards of $2k, plus the cost of the heads, if that's what it is. Your best bet is to also have ARP head studs installed at the same time. You can drive it with blown HG's, but you should have this concern verified by a Ford diesel tech soon and have them explain it to you so that you can make an educated decision. Good luck!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
