Another "white smoke" question - Ford Powerstroke Diesel Forum
post #1 of 26 Old 08-20-2013, 07:10 AM Thread Starter
I have an 07' 6.0 and recently noticed some white smoke coming out of the exhaust. It's not bad, and it only happens on excelleration. Now I've read a ton of post on here and everyone seems to have worse symptoms than I do. My truck through the p0401 code about 2 weeks ago. Took the egr valve out, cleaned it, cleared the code and the CEL hasn't come back, but now it's blowing a little cloud of white smoke and I've noticed when I get on it not all my power is there. When I get to about 50mph and continue to get up to speed it pukes a cloud of black smoke as well and kinda studders a little. I've read anything from its my egr cooler(which my egr delete will be here today) to its a bad turbo seal. Any help is appreciated
ColbEMT is offline
post #2 of 26 Old 08-20-2013, 08:12 AM
poorboy1964's Avatar
Quoted: 2 Post(s)
When you took out the EGR to clean it was it dry or damp inside? if Dry the shudder and black smoke? I would check your FICM voltage make sure it's not dropping, sometimes white smoke can be unburnt fuel.
Tom
2003 CCSB 4X4 6.0 Born on 5/03 Tuned by Vivian, 4" Turbo Back Exhaust, Edge CTS w/EGT, Coolant filter. ELC. fuel pressure gauge,
2002 SCLB 4X4 7.3 Stock
poorboy1964 is offline
post #3 of 26 Old 08-20-2013, 09:26 AM Thread Starter
It was dry for the most part. There was one little clump of carbon that seemed a little moist
ColbEMT is offline
post #4 of 26 Old 08-20-2013, 10:09 AM
Quoted: 2 Post(s)
your on the right track with the Delete, here is a vid for the test on the FICM if you haven't seen it, do you have any kind of monitor if not start looking for one. the link I posted is a good one if you haven't read it.
Write Up: Monitoring the 6.0L PSD.
Tom
post #5 of 26 Old 08-20-2013, 10:18 AM
White smoke upon starting in VERY COLD weather means not all the cylinders are firing, and raw fuel is coming out of exhaust pipe. It quickly goes away as engine slightly warms.
White smoke after engine is warm means coolant is getting in your cylinders.
Aufgeblassen is offline
post #6 of 26 Old 08-20-2013, 06:42 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Sounds like a Possible egr cooler issue.
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #7 of 26 Old 09-10-2013, 09:03 AM
What about white smoke (steam) on cold startup in summer??
2005 Excursion 6.0L [121K]
1998 Harley Ultra Classic [71K]
2003 Montana 3295RK
2011 Rockwood Roo 21SSL *SOLD*
DashBOSS
GlowShift gauges (fuel press, boost, EGT)
Sinister Diesel Coolant Filter
Sinister Diesel Intake Elbow
Blue Spring upgrade
OEM Metal CAC Upgrade
RiffRaff CAC Boot Set
Sinister Diesel Thermostat Housing
turbo rebuild
EGR Delete (
SCT 3015, Street tune
dhbpac is offline
post #8 of 26 Old 09-10-2013, 09:17 AM
Coolant getting into cylinder. Unless somehow the fuel you bought had water in it.
post #9 of 26 Old 09-10-2013, 09:54 AM
Damn. That's what I thought. Welp ... got my new weekend plans!
2003 Montana 3295RK
DashBOSS
Blue Spring upgrade
turbo rebuild
EGR Delete (
dhbpac is offline
post #10 of 26 Old 09-10-2013, 12:04 PM
I had a Ford Escort diesel that used about a coolant reserve bottle full of coolant per week, but had no other consequence; I just kept refilling it.
If it runs fine, and your oil does not appear to be getting milky in appearance, I would not worry too much.
Stop leak my solve the problem.
