No luck with smoke in cab an loss of boost! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-19-2013, 07:37 AM Thread Starter
cadetw32's Avatar
So I'm still at a stand still with my 05 dually I'm runnin the sct livewire ts now I have terrible screeching sound from what sounds to be from the turbo but neither the inducer nor exducer seems the be rubbing the housing and still haven't found any cracks in the bellows or poor sealing from the up pipe to the turbo...I can only build about 1000rpms of boost if that and if I do black smoke pours into the cab from vents and under the hood is completely black please help!
cadetw32 is offline
post #2 of 4 Old 08-19-2013, 09:26 PM
Get a bunch of non-chlorinated brake cleaner, clean off all mating surfaces and bellows with the exhaust. Man to heads, man to up pipe, up pipe joint by egr cooler, awhere the egr cooler is, up pipe to turbo, and the intake where the egr and egr cooler is. After its clean and dry, have a friend start it and rev it while you look for smoke. Theres really no way to test it other than to see it. Unless you can somehow blow smoke into your tailpipe with engine off. Not sure how but it can be done.
468 HP & 873 Ft-Lbs
2005 F-350 SRW 4x4 CC Long Bed
SPD tune by Chris @ Truck Source Diesel
ARP Head Studs
3.5" DP to 4" Straight Pipe
Banks High Ram Air Intake
K&N CAI
Edge Evo CTS w/ Backup Camera to monitor
MTS HD Direct Drive Solenoid
Updated:
Standpipe & dummy plugs
Turbo feed & drain tubes
HPOP & IPR screens
Blue Spring
ajfrac is offline
post #3 of 4 Old 08-19-2013, 10:31 PM
You may want to check your air filter or for a restriction of airflow, rag in air duct or clogged cac.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 4 Old 08-20-2013, 04:03 AM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
My vote cracked flex pipe, mixed with underlying issues
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
