Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 10-18-2006, 09:52 AM
venomous venomous is offline
03 F250 needing ball joints
I just checked out my truck earlier to see if I had front end problems or just needed an alignment and I realized I need drivers side upper ball joint. I plan on doing the upper and lower at the same time and if I have enough funds then I'll do both sides while I'm at it. My question is will I need any special tools besides a ball joint press to remove and install the ball joints. I remember seeing a special socket one time that was used to remove and install the ball joint camber shim so I just thought I'd get the low down before I start buying parts and tearing into it just to find out I don't have what I need as this is my daily driver.
Old 10-18-2006, 10:29 AM
Marty Marty is offline
International Threat
Not 100% sure about that, but I have a link here where I bought my wheel bearings. They have ball joint kits for you.
http://catalog.powerstrokeshop.com/p...tegoryID=84614
Old 10-18-2006, 11:48 AM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
So how many miles did you get outa those ball joints?
I have an 03 also with 55k miles so i was wondering what I have to look forward to as far as that goes.
Old 10-18-2006, 07:33 PM
mschn99 mschn99 is offline
No other special tools needed besides the press.......other than the fact that you will want the backside hub..sometimes called an excluder seal....replaced. It takes a special tool to install that seal but for the price of the tool used to press it in place, you would probably be better off arranging having the local dealer install them on each axle for you for whatever they would charge
Old 10-19-2006, 10:10 AM
The truck started feeling funny at 91,000 miles which is when I bought it so I didn't check anything until 97,000. Marc you wouldn't happen to know who sells this tool or who makes it. I'm all about having the right tool for the job and I don't let anyone work on my vehicles unless I need some exhaust bent up.
