6.0 startup issue - Ford Powerstroke Diesel Forum
post #1 of 27 Old 08-17-2013, 01:15 PM Thread Starter
6.0 startup issue
I have an 03 F250 6.0 with 77000 miles on it. Has an egr delete, 3.5 inch straight pipe, and sct custom tuner from innovative diesel currently on 160hp tune, everything else is stock. Go out in the morning or after setting for about 6 hours to start and has fairly decent puff of white smoke along with a rough idle for a second or two tops then its fine. After it has been running it starts normally with no idle problem or white smoke at all. No smoke at heavy acceleration, idle, or take offs. Switched back to stock for a few days and problem was gone. I have checked coolant and oil numerous times and they are holding steady. Any ideas or help would be greatly appreciated.
tator92 is offline
post #2 of 27 Old 08-17-2013, 08:27 PM
Cold start issues are usually FICM, electrical, or injector stiction related. I would do a test of your FICM voltage while cranking the first start of the day. Theres a good youtube video showing the process. To make things easier, get th assorted vaccum caps from autozone or similar, to plug the barb for the coolant line on the degass bottle. Youll need 8mm socket, volt meter, I believe a torx bit for the ficm, and a friend to help.
468 HP & 873 Ft-Lbs
2005 F-350 SRW 4x4 CC Long Bed
SPD tune by Chris @ Truck Source Diesel
ARP Head Studs
3.5" DP to 4" Straight Pipe
Banks High Ram Air Intake
K&N CAI
Edge Evo CTS w/ Backup Camera to monitor
MTS HD Direct Drive Solenoid
Updated:
Standpipe & dummy plugs
Turbo feed & drain tubes
HPOP & IPR screens
Blue Spring
ajfrac is offline
post #3 of 27 Old 08-18-2013, 07:31 AM
Maybe you should have your tune checked since not useing the tune everything worked ok.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 27 Old 08-18-2013, 12:35 PM Thread Starter
Just did the FICM test and it had 48.2 Volts in the on position and while cranking had no less than 47.4 followed by back to 48.2 at startup. Is there anything i could do additive wise that might tell weather or not an injector is sticking without having to remove them? I think tomorrow i will call out to innovative diesel and see about a bad program. Buddy of mine says it is bad injectors but if it was bad then it would puff the cloud whether on stock or a program id think.
tator92 is offline
post #5 of 27 Old 08-24-2013, 11:28 PM Thread Starter
Does anyone know if using a fuel treatment could cause the start up problem. I use Howes at a 2.5 oz per 5 gallon mixture as the bottle states. I filled up the other day and today never had the problem once even after setting for 12 hours.
tator92 is offline
post #6 of 27 Old 08-25-2013, 02:17 AM
While I am not partial to mechanic-in-a-can soloutions additives are what is commonly used to clear up fueling problems [stiction] etc. Never seen one actually cause problems.
post #7 of 27 Old 08-25-2013, 06:53 AM
ps_lane01's Avatar
Quoted: 7 Post(s)
White smoke could be an injector sticking open and over fueling or ficm- but you can check the ficm off ur list. Interesting that would happen with a tune but not stock.
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #8 of 27 Old 08-26-2013, 04:54 PM Thread Starter
Thats what i thought about the additive. It was suppose to help clean it up and prevent problems but its only done the symptom once now since i filled up and it wasnt even that bad compared to the rest i thot so im thrown for a loop. As for the injectors possibly leaking off i wudnt think it wud change wheathed it was on stock or with a program under the assumption the programmer doesnt up the fuel pressure. Could it be from lack of air maybe on a cold start since it still has factory air setup? I also remember comming across something about a check ball of some sort that is opened by the fuel filter i think. Something about it has to be a ford fuel filter or it doesnt work right with opening it all the way. I put a wix one it for fuel and oil. Could the ficm also pass a test one day but fail the next and actuallly be bad?
tator92 is offline
post #9 of 27 Old 08-26-2013, 05:05 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
Programmers change the fuel map or the desireved fuel air ratio depending on alot of conditions. fuel pressure is mechanically controlled by the spring inside filter housing .. Go to ford and get motorcraft fuel filters and oil filter. I am not sure if wix has the same design for the secondary filter, but the motorcraft primary hfcm filter has a special coating which is neccessary for filtering water and contaminants. The money your saving with cheap filters is nothing compared to a set of injectors or hpop.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #10 of 27 Old 08-27-2013, 11:10 AM Thread Starter
So there is a difference of quality for actual ford filters. Ill change em out when i get time too. Last night i was talking with a coworker who has a cummins about the smoke at start up. He was sayin his does it on a high horse setting but not on a lower one just from cranking and putting fuel in the exhaust then firing and not burning whats been dumped. Any thoughts on that. Be the first time i have heard of this.
tator92 is offline
Tags
2003 , 6.0 , f250 , rough idle , smoke
