EGR question - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-14-2008, 05:21 AM Thread Starter
EGR question
I've seen alot of posts about how to delete the EGR. They all talk about welding the hole shut. My question is, what happens when you just unplug the EGR? Does it lock in the open or closed position? If it's the open then I can see welding the plate shut and deleting the EGR.
Thanks
swasenko is offline
post #2 of 16 Old 05-14-2008, 06:26 AM
breuer69's Avatar
I'm not a tech, but I would think that just "unplugging" the egr would cause it to post DTC's and a CEL.
2006 Ford F250 CC Lariat, SB FX4, 6.0L PSD, 5R110
2006 Mercury Mountaineer Premium 4.6L 3V AWD
1989 Ford Mustang LX Hatch. 5.0 (on a stand), AOD (T5 swap in the future).
breuer69 is offline
post #3 of 16 Old 05-14-2008, 02:28 PM Thread Starter
Unplugging it actually made my dtc's go away. If you would weld the flang shut and delete the egr it would send dtc's also wouldn't it?
swasenko is offline
post #4 of 16 Old 05-14-2008, 02:36 PM
icedevil's Avatar
call me a newb if you want what is the purpose of the egr? what does it stand for and why do people block it off? sorry, i dont mean to hijack the thread
2007
F350, single rear wheel
X2000 tonneau cover
Polk Audio 5x7 front and rear, soon to upgrade to component speakers, powered by Pioneer 600W 4 channel
4" Silverline Turbo-back exhaust with Black SS tip thanks to Kyle@XDP
I dont know why i waited so long, this sounds absolutely killer!
pics coming soon!!!!
icedevil is offline
post #5 of 16 Old 05-14-2008, 06:07 PM
Slacker
Evil Eye's Avatar
Quoted: 223 Post(s)
Feedback Score: 4 reviews
Unplugging it will prevent exhaust from reentering the intake, so that will work and some do and some don't throw a CEL based upon the year of truck and the PCM strategy. You might also want to block off the EGR cooler, so the hot exhaust gasses don't get dead headed due to the closed EGR valve and heat soak the cooler. These EGR coolers are notoriously weak, so you should consider blocking them off.
EGR stands for Exhaust Gas Recirculation, which means that some of your exhaust is reinjected into your manifold to reduce emissions. People block it off because the EGR valves get coated in soot and stop working properly. The EGR valve is commanded open only when the engine is operating at a certain level, not all the time, so when it gets stuck open, the engine starts to run pretty poorly (surging, stalling, generating black smoke, etc).
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #6 of 16 Old 05-14-2008, 06:23 PM
Rice Hunter
Diesel Freak's Avatar
Yup,,, Shawn said it well
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #7 of 16 Old 05-15-2008, 06:46 AM Thread Starter
Awesome, so unplugging it does lock it closed. How do I block off the EGR cooler? Thanks for the help.
swasenko is offline
post #8 of 16 Old 05-15-2008, 06:50 AM
Baller1771's Avatar
Send a message via AIM to Baller1771
how do you unplug it?
Dillon- ILLIANA art director
Click to hear 03 Turbo whine Straight pipe
Baller1771 is offline
post #9 of 16 Old 05-15-2008, 10:40 AM
Slacker
Evil Eye's Avatar
Quoted: 223 Post(s)
Install either a block off plate or freeze plug at the y in the up-pipe leading to the EGR cooler.
Disconnect the wiring harness on the EGR valve.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #10 of 16 Old 05-15-2008, 07:44 PM
dnf12908's Avatar
Quoted: 34 Post(s)
[quote=Evil Eye;585249]Unplugging it will prevent exhaust from reentering the intake, so that will work and some do and some don't throw a CEL based upon the year of truck and the PCM strategy. You might also want to block off the EGR cooler, so the hot exhaust gasses don't get dead headed due to the closed EGR valve and heat soak the cooler. These EGR coolers are notoriously weak, so you should consider blocking them off.
I've had my EGR cooler unplugged for the last 5000 miles or so, and have had no issues. I just read in the June 2008 issue of Diesel Power (Postal Route pg. 29) that the '03 and early '04 had a better designed cooler, so maybe those ones are less prone to failure.
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Edge Insight monitor
Harley headlights w/Gensii LED bulbs
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
