Vgt duty cycle messed up/ no whistle. HELP!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-15-2013, 07:21 AM Thread Starter
Ok so I have a 05 6.0. My vgt duty cycle is at 45.0% at idle and drops to about 24% wot. I have an exhaust back pressure circuit low and circuit high codes. So I replaces that with no change. Next I changed the map sensor because these 2 sensors tell the computer the vein position (thought mabe that would help). Still no change. Cleans the unison ring and veins last night, put a new vgt solenoid in and also the plug. No change. Wtf. I have a powermax in this and only pushing 28psi with a 100 horse tune in the edge. Does anyone have ideas.
Damian886 is offline
post #2 of 5 Old 09-21-2013, 08:08 AM
I have the same problem...you figure out what it was?
7.3ghost is offline
post #3 of 5 Old 02-08-2015, 02:03 PM
same problem now did anyone figure it out lol
2005 F350 ccsb way to many things to list
mderrickson216 is offline
post #4 of 5 Old 02-08-2015, 03:34 PM
05KRPSD's Avatar
Did you clean or replace your ebp sensor? Did you clean the tube going to the sensor?
John
2005 F350 King Ranch
AFE cold air intake
Magnaflow 4in turbo back
Swamps 58v ficm(Never sees 58v
Diesel Site coolant filter/ELC coolant
Egr delete
Blue spring mod
B&W Gooseneck hitch/Companion Fifth Wheel
05KRPSD is offline
post #5 of 5 Old 02-09-2015, 03:27 AM
yeah it was clogged cleared it up a little but doing that cleaning map nipple replaced tube cleaned turbo ordered a new ebp sensor cleaned vgt solonoid gonna pull the ait out and clean it today also gets better little by little egt wise but still no whistle until high idle also running a powermax and only 28psi a wot with a gearhead extreme tune
