No start after negitive battery cable come off - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-14-2013, 09:45 PM Thread Starter
Been searching for an answer for hours. tried several possible solutions. looking for help.
Was driving the truck yesterday and went to start it after it sat for 10min. For a brief fraction of a second it turned over normal then the RPM of the starter turning the engine over dramatically reduced. and the truck won't start. Opened the hood to find the neg battery cable disconnected from the driver's side battery. reconnected it no change. have had the batteries checked at two places. other than the passenger side battery being low on charge the both checked out fine after charging the passenger side battery. the only error coders are p1000 and p0603 which i think are from disconnecting and reconnecting battery. checked all fuses and relays seem to work (can feel them click when ignition is turned on and starting). I hear the fuel pump running when I turn key to run. I put new starter in B/C it is only cranking at 78rpms according to the edge monitor (it's my understanding 200 is minimum for the 6.0L to start). but even with the new starter itdid not improve much 100RPM it will almost want to start sputter RPM will reach 150-200 hit 400 once It sounded like it was going to keep running but alas not. Engine parameters I've monitored are FCIM sync (1), FCIM voltage (48-47.5), inject pressure (1200), inject pulse with (2-3), engine RPM usually 75-100.
Two thinks that have me wondering after only 30 sec of cranking on the fully charged supposedly good batteries (3 mo old) there is a noticeable drop in engine RPM and the passenger side battery will draw 4 amps on the charger. I think this might be the issue when it was load tested the guy only put a 450amp draw on it. The other potential cause is when I crank the engine the Oil pressure gauge doesn't read. now I never look to see if it did while craning before but In my search for the problem one poster said to look for this as it might be a faulty oil pressure sensor causing the engine no to start. I would think this would throw a code though. any suggestions
vaulter is offline
post #2 of 7 Old 08-14-2013, 10:47 PM
KCCO!!
kells17's Avatar
What caused your battery cable to come off? No worries on your oil pressure gauge, it won't show pressure until your truck has started. Any prior issues?
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #3 of 7 Old 08-14-2013, 11:09 PM Thread Starter
I that battery cover didn't allow the negative cable to seat really well on th post. with the clamp tightened fully it still could be turned on the post (not easily but over time I could see how it could work it's way off with the cover pushing up on it ex.. I could not pull it of but could rotate it and if I had the patients I imagine I could work it off over time) I bent the connector to fit the cut out in the cover better so the clamp will sit deeper on the post and I can no longer turn it when fully tightened. No prior issues but I've only owned the truck for 2 mo. and put 1500mi on it alos I don't know the history as I bought it at an auction.
I thought my profile would bring up my truck info.
If it is helpful
2003 f350 DRW 6.0L crew cab 4x4 K&N air intake, remote coolant filter, 4" turbo back exhaust, edge CTS evolution controller
vaulter is offline
post #4 of 7 Old 08-15-2013, 07:44 AM
I vote for blown fuse when the cable came off
powerstroken00b is offline
post #5 of 7 Old 08-15-2013, 09:37 AM Thread Starter
What fuse I pulled and checked every fuse in the box. And why would that cause the engine to only turn over at 78 RPM
vaulter is offline
post #6 of 7 Old 08-15-2013, 04:00 PM Thread Starter
begining to wonder if the battery cable was just a coincidence. ICP while cranking 45, IRP 85 at RPM of 75
vaulter is offline
post #7 of 7 Old 08-15-2013, 07:17 PM Thread Starter
The AC compressor locked up and wouldn't let the engine crank fast enough to build oil pressure and or start. Better than the LPOP I was worrying about. Add the AC compressor to possible causes of no start issues. I should have realized with the slow turn over but the negative batt cable had me thrown off
vaulter is offline
