HG emergency - Ford Powerstroke Diesel Forum
post #1 of 20 Old 08-13-2013, 11:16 AM Thread Starter
HG emergency
So I just tried cranking my 05 6.0 up after studs and cooler, ive cranked for a combined total of 3 minutes or so. ICP is reading about 2 psi during cranking. Im worried I damaged the branch tube or something. I tried unplugging icp still nothing.
Whats the normal time it takes to crank up after hg?
Should I see icp rise at all?
How much cranking does it take to start?
Whats duration and frequency of cranking is best to not damage starter?
Thanks
ajfrac is offline
post #2 of 20 Old 08-13-2013, 12:45 PM
Everytime I have started a 6.0 after head removal I have started with a battery charger hooked up. I crank for approx 20 sec. After doing this 2-3 times I usually see baseline oil pressure. After that it always starts on the next crank. I usually give it a minute or so in between try's.
Sent from AutoGuide.com App
13 f-350 ccsb platinum
05spudman is offline
post #3 of 20 Old 08-13-2013, 12:46 PM
Quoted: 6 Post(s)
Does the oil pressure gauge on the dash come up?
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #4 of 20 Old 08-13-2013, 12:48 PM
Yes. Make sure to check your oil after cranking a few times. It could be low if you changed your oil cooler.
post #5 of 20 Old 08-13-2013, 12:55 PM Thread Starter
I poured oil in where the filter standipe goes to fill the cooler. Ill check the levels. As far as the gauge on the dash, ive never seen oil pressure until its started, never when cranking. Im at a drs appt now but ill keep trying when I get home. I was able to get an icp of about 16psi. Sometimes ill crank it and it will stay the same. Sometimes I crank it and it goes up a few psi.
ajfrac is offline
post #6 of 20 Old 08-13-2013, 03:19 PM Thread Starter
Ok, oil level is good, the filter area is filling. Now icp wont go above 9.5 psi. Im going to keep trying every so often and if it doesnt start by thursday im towing it to a dealer to trade in.
ajfrac is offline
post #7 of 20 Old 08-13-2013, 03:28 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
Did you put the dummies in the correct hole? Usually the problem is in the injector hold downs, the oil rail and wiring/connection issues. 9.5psi means nothing if the IPR isn't closing, or it is commanded closed but remains open.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #8 of 20 Old 08-13-2013, 03:46 PM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #9 of 20 Old 08-13-2013, 08:57 PM Thread Starter
Fantom you just made my day with that. The reality is that ive spent alot on this truck and have only owned for less than a year. But I owe too much on it to trade in, so its cheaper to just get it fixed at the dealership than to pay the difference on my loan. Ill check the pigtail for the ipr tomorrow night. After that its off to the dealership to get fixed. Ive got way to many other things going on to be down a vehicle and trying to figure out what it is. If im not mistaken , the ipr plug should have + and - 12v correct?
ajfrac is offline
post #10 of 20 Old 08-14-2013, 02:30 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
9.5 psi means it isn't going to start. ICP psi needs to be up around 450 to start IIRC.
RIP Mitch
the Org crew
PGreenSVT is offline
