6.0l woes - Ford Powerstroke Diesel Forum
post #1 of 13 Old 08-12-2013, 09:01 AM Thread Starter
Question 6.0l woes
I have a 2006 6.0, ran like garbage, #4 and # 7 injectors were bad so decided to go through and replace all of them, at the same time replaced the dummy plugs and stand pipes along with the updated STC fitting. After all that the truck no wont start, gone rounds with it and do not have a scanner to read any of the pressure. Any thoughts or ideas would be greatly appreciated!!!!!!!!!!!!!!
stacked_ford is offline
post #2 of 13 Old 08-12-2013, 09:21 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 29 Post(s)
Feedback Score: 4 reviews
Maybe left a ground unplugged, or a sensor. Without codes it seeing it, it's hard for me to say. Maybe someone with more knowledge can help.
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #3 of 13 Old 08-12-2013, 09:56 AM
proamas's Avatar
How long did you let it crank? It take a long time for the HPOP to fill back up and pressurize the system. At least 60 seconds on / off cranking.
You can get a Scangauge II at Autozone for 159.00 its a really good cheap tool to help diagnose, and program in the specific PIDs you need.
proamas is offline
post #4 of 13 Old 08-12-2013, 11:25 AM Thread Starter
I let it crank for quite some time. It also appears that im not building low oil pressure. The oil filter housing is not filling with oil at all and even with the new injectors it seems that I still hve a leak under the valve covers, what are the odds that it is the high pressure rail into the injectors?
post #5 of 13 Old 08-12-2013, 11:50 AM
2006PSDSD's Avatar
Quoted: 29 Post(s)
You know the oil filter housing has a drain in it right? Page 25: Lubrication System
You really need to get those codes, or risk replacing unecessary parts
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #6 of 13 Old 08-12-2013, 01:58 PM Thread Starter
Read the codes all they are is the EGR circuit low
And fault, due to the EGR delete, other than tht I pressed te plunger in the bottom
Of the oil filter housing while cranking and nothing, why is making me lean towards low oil pressure, thoughts
post #7 of 13 Old 08-12-2013, 02:57 PM
mastrkee's Avatar
Quoted: 3 Post(s)
It can take two or three minutes of actual cranking time to get the pressure to build. of course not more that 15 or 20 seconds at a time, ( I know I didn't need to say that, right?!!)
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #8 of 13 Old 08-12-2013, 05:54 PM Thread Starter
Yep, did that and still nothing
post #9 of 13 Old 08-12-2013, 05:58 PM
Powerstroke Techie
Quoted: 15 Post(s)
Garage
okay so all you had opened up was the high pressure oil system.... STC, oil rail plugs, standpipes and injectors correct? You didn't miss the yellow o-ring underneath the high pressure oil pump did you? That is where base oil pressure supplies the high pressure pump. It could cause a pressure loss theoretically but perhaps not as large as you describe.
With no base oil pressure you may have a stuck oil pressure regulator or some worn out gerotors. any pieces missing from the injectors or STC fitting? I have had injector clips and STC fitting clips both lodged in the oil pressure regulator before.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #10 of 13 Old 08-12-2013, 06:52 PM Thread Starter
Yep that is what has been apart thus far. The yellow o ring under the pump is in place also the o ring under the STC fitting is in place. It did not appear that anything is missing on the injectors or the stc fitting.
