2005 6.0 won't crank! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-11-2013, 11:59 AM Thread Starter
I removed my dash the other day to look at the back of my radio because my sub isn't working. After I put the dash back on and reconnected the batteries, the truck didn't start. I made sure the connections were good and checked all of the fuses. I replaced the starter relay because I don't know how to check it! After that we replaced the starter, and nothing. Then we replaced the batteries, still nothing! I've done everything I could think of. I've unplugged the fan clutch and tried to start it. I've put it in neutral and jiggled the shifter while trying to crank it. I'm so lost! Thanks in advance
Also, the small wire reads 15-18v while the key is on, but when I try to crank it the voltmeter reads 0. I do hear all of the engine components warming up, and I hear a click in the fuse box when I turn the key.
msansing is offline
post #2 of 3 Old 08-11-2013, 12:32 PM
mastrkee's Avatar
Quoted: 3 Post(s)
You removed the whole dash?
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #3 of 3 Old 08-11-2013, 12:49 PM Thread Starter
Enough to get the radio out.
msansing is offline
Tags
6.0 won't start
