No power after replacing Oil cooler - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-11-2013, 12:48 PM Thread Starter
I recently replaced my oil cooler, I have no power whatsoever. Max boost is 3 psi. My wires going to the connector on the VGT was accidentally broke. I repaired that, even to the point of making my own Pigtail to reassure that I had a good connection. I tested the VGT solenoid for proper ohms, everything was good there. Pretty sure that I do not have any leaking pipes going to or from the Turbo. I don't really see the vanes on my turbo sticking as the turbo was working fine before I removed it. Any info would be great.
Foxstar is offline
post #2 of 12 Old 08-11-2013, 12:50 PM
ps_lane01's Avatar
Quoted: 2 Post(s)
Unplug the pigtail does it make a difference in sound when running? Sounds to me like a typical exhaust leak
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #3 of 12 Old 08-11-2013, 01:25 PM Thread Starter
There is a different sound pitch when its plugged vs unplugged. I have another correctly running 6.0 here and I unplugged that one as well. Both sound very similar. That tells me that its working properly. Also I did a ohm test on both solenoids and wiring they are very close to each other. I could not feel any exhaust leak around the turbo or hear any leak.
Foxstar is offline
post #4 of 12 Old 08-11-2013, 02:58 PM
Quoted: 50 Post(s)
Any DTCs showing?
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #5 of 12 Old 08-11-2013, 04:11 PM Thread Starter
Originally Posted by skanj0 View Post
Any DTCs showing?
P0046- I am currently back tracking all my connections to ensure everything is properly plugged/ good contact.
Foxstar is offline
post #6 of 12 Old 08-11-2013, 04:29 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Intercooler boot?, I'd almost bet it's an exhaust leak at the flange from flex pipe.
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #7 of 12 Old 08-12-2013, 07:00 PM
Boozer76's Avatar
Intercooler boot would definitely do it but be so obvious. Can the OP hear a leak? Should be a damn substantial hissing sound if you're maxing 3psi.
My Album
Currently stock engine 52k miles.
4.5" Icon lift kit
Rockcrusher front and rear diff
Procomp A/T Extreme tires
full tint on all windows
Blue Spring Update
SCT tuned, canned performance for now
Straight pipe MBRP Turbo back exhaust
XDP EGR delete kit
Boozer76 is offline
post #8 of 12 Old 08-12-2013, 07:15 PM
ps_lane01's Avatar
Quoted: 2 Post(s)
If the op has a tuner put it on a high hp tune and put it in park and have someone step on the gas real quick to blow some soot. If you have an exhaust leak you will be sure to see the soot poof out... The op would def hear a leak if 3psi is all you can see
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #9 of 12 Old 08-13-2013, 08:50 AM Thread Starter
Problem solved!! Tracked down the MAP sensor hose, right above where it attached to the intake there was a crack in the hose. Cut out the bad section and problem solved making plenty of boost! This problem took me a couple of days to figure out. So glad its finally fixed.
Foxstar is offline
post #10 of 12 Old 08-13-2013, 10:32 AM
Boozer76's Avatar
Great news!! Thanks for the update!
My Album
4.5" Icon lift kit
Blue Spring Update
XDP EGR delete kit
Boozer76 is offline
