Fuel gauge broken after sump pump install - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-10-2013, 05:25 AM Thread Starter
05diesel60's Avatar
So I had a sump pump installed on my truck and they lowered the fuel tank for the job in order to keep everything clean and out of the fuel tank. So my wife picks up the truck and fills it up and then the dash screen said "Fuel Level, Data Error"
So what is causing this problem? Is there a connector not plugged in or what?
Thanks in advance.
2005 Powerstoke CC SB Lariat
SCT X3 Tuned by Eric @ IDP
, Edge Insight, FICM Upgrade with Re-flash, Fabtech 6" Performance Lift with 35" M/T Baja ATZ's, Banks Turbo Back Dual 4" Exhaust, Kitty Delete, Banks Intake, Banks High Ram Intake, Banks Intercooler, Garrett Powermax, Casserly 155cc Injectors, AirDog II, Blue Spring Upgrade, 6.4 Banjo Bolts, EGR Delete Kit, Mag-Hytec Rear Diff. Cover with Eaton True Trac, CAT ELC, ARP Head Studs, Royal Purple Oil, Rev X Oil Additive
05diesel60 is offline
post #2 of 3 Old 08-11-2013, 06:37 AM
4506.0's Avatar
Most likely.
16 F350 CC LB DRW 6.7 FX4
4506.0 is offline
post #3 of 3 Old 06-25-2014, 12:10 PM
All-Right Hauling & Trans
TurboMustang370's Avatar
Quoted: 13 Post(s)
Ever find the cause and/or solve the issue?
2004 Ford F-350 XLT Dually: crew cab, 8' box, Sinister Mfg. EGR delete, NUC/Amsoil by-pass oil filter, DC Power 185 w/ FICM Repair's full wiring kit, Diamond Eye exhaust, Techni-Cooler, SCT/Gearheads tuning, Edge Insight CTS w/ EAS EGT & FP, Tekonsha Prodigy P3, Line-X and B&W turnover gooseneck.
TurboMustang370 is offline
