chatter/grinding when accelerating :/ - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-08-2013, 05:30 PM Thread Starter
Well i recently pick up an 06 powerstroke, had a few minor things with it but overall truck is great, i had a hesitation issue under wot but after a crankshaft position sensor, new fuel filters, seems to be gone. Im getting like this chatter noise under hard acceleration. i was going ill say around 35 gradually on it pretty hard and then to the floor (didnt downshift) and i got like a chatter or grinding kinda felt like it was underneath me i was thiking something with the transfer case....so i stop and tried it from a stop not wot but hard and it does the same thing, normal driving its fine but once i get on it it makes a grinding noise...i thought it may be tranny slipping because it sorta feels to be slipping when the noise happens but it seems to loud and i feel it to much for it to be that tranny slippage from what im used to never really makes noise, this is loud...im going to try and get a video up by tomorrow to show you guys..
06banks is offline
post #2 of 5 Old 08-08-2013, 05:34 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Carrier bearing? U joint? Rear end fluid?
Sent from AutoGuide.com App
2005 F350 CCLB FX4
juniorssrollin is offline
post #3 of 5 Old 08-08-2013, 07:26 PM Thread Starter
thanks yeah from what i read it sounds like the carrier bearing and i guess with that worn it will cause the u joints to go.. i went out to make a video but you dont really hear it but to maybe help with the description a lil i went and found the biggest hill around and was going about 20 mph then gave it maybe 3/4 throttle not enough to downshift just enough to get the turbo spooling and accelerate and it did it pretty bad, i can feel it in the petal also so im assuming if i was towing i would have noticed it alot more and it feels like its coming from under the truck directly beneath the radio..
06banks is offline
post #4 of 5 Old 08-08-2013, 08:09 PM
crash&burn's Avatar
Sound will travel. I have seen it some dump trucks I used to work on. Sounded like it was in the tranny but was in the rear end. I also heloed buddy recently with a limited slip rear end maoing sounds as you describe and the rear end was toast. Just what I have seen
Shawn
2004 CC F350 - 4-5" exhaust no cat - CTS Insight with turbo timer and Egt's - EGR Delete - K&N - Coolant Filter
SCT with Custom Tunes - MTW MadMax - 190/Stock - PTP Solenoid - Blue Spring - A few mystery switches
crash&burn is offline
post #5 of 5 Old 08-09-2013, 12:36 AM
Quoted: 2 Post(s)
Get under it and see what kind of shape the carrier is in
2005 F350 CCLB FX4
