2005 F350 won't crank. low oil preasure.!!! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 08-08-2013, 03:33 PM Thread Starter
cranked truck today. Reved engine a few times and cut off. Tried to recrank and no start. All I have is factory guages but oil preasure never moves during long crank. New hpop around 100k. Truck did same thing around 130k and replaced IPR. Now have 145k. Anyway pulled IPR today and the screen is 100% clogged with small white pieces of rubber or plastic...do you think a new valve will get me going again? What could the trash be? Hpop entrails? ? Thanks!
Pair of Hounds is offline
post #2 of 13 Old 08-08-2013, 05:13 PM Thread Starter
Any thoughts? Need to get back on the road. .. thanks!
post #3 of 13 Old 08-08-2013, 05:33 PM
4506.0's Avatar
So it won't crank or it won't fire?
16 F350 CC LB DRW 6.7 FX4
4506.0 is offline
post #4 of 13 Old 08-08-2013, 05:39 PM Thread Starter
Cranks but no start/fire
post #5 of 13 Old 08-08-2013, 05:44 PM
The white parts could possibly be from the filter / screen under the oil cooler. That's the next part upstream, and it should stop anything visible. If so, replacing the IPR is temporary.... need to replace the screen so you may as well the oil cooler
Hauser is offline
post #6 of 13 Old 08-08-2013, 06:23 PM
4506.0's Avatar
Hauser is right on there.
Using OEM oil filter?
4506.0 is offline
post #7 of 13 Old 08-08-2013, 06:31 PM Thread Starter
Replaced oil cooler and screen myself about 5k Ago. Previous screen was no good. Maybe something got by then..???
post #8 of 13 Old 08-08-2013, 06:36 PM
4506.0's Avatar
Did you replace it with the updated screen? OEM oil filters?
4506.0 is offline
post #9 of 13 Old 08-08-2013, 06:48 PM Thread Starter
Replaced it with screen that came with cooler from oreilly... filter was something I had for awhile and not top of the line.
post #10 of 13 Old 08-08-2013, 07:06 PM
4506.0's Avatar
If the screen wasn't the updated stainless one, it's worthless essentially.
If you aren't using an OEM filter and cap, you are doing constant damage to the engine...
4506.0 is offline
