new alternator. .now voltage is too high? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-05-2013, 01:45 PM Thread Starter
I recently installed a napa 135 amp alt. Now I have some intermittent problems with low and high volts while running. Low meaning 11.5 range, high, 15 to 16v. The low condition only showed a few times within a week following install. Now about a month has gone by and I am starting to see these high reads on my live wire ts. I am also loosing all dash board instruments and radio during hi volt. I assume the loss of dash power is some sort of safety function. Guess what I would like to know is the alternator regulating voltage out put or is there a separate regulator causing me grief? Thanks for any help! Jeff
06 f350 CC SB FX4 XLT UPFITTER, TOW COMMAND, CHROME PACKAGE, MOON ROOF:
ARP STUDS, EGR DELETE, FORD OIL COOLER, STC , DUMMY PLUGS AND UPPIPE, BLUE SPRING, BANJO GUT AND DRILLED, COOLANT FILTER , CAT EC-1, GRAND ROCK TURBO BACK CAT DELETE 4"/ 5", 58v FICM, 2.5"lift level, LIVEWIRE TS... WORK IN PROGRESS:
hvac man is offline
post #2 of 3 Old 08-05-2013, 01:46 PM
Snake's Avatar
Quoted: 46 Post(s)
Sounds like the NAPA alternator is bad.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #3 of 3 Old 08-05-2013, 02:58 PM
Bring it back. The voltage regulator is bad
Moto2four is offline
