2003 6.0 F350 Error Codes - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-03-2013, 11:15 AM Thread Starter
Truck won't start when hot, bully dog shows the following error codes;
U0229
P132;
P-#06
Found the first one (U0229), heated steering wheel module? don't have one of them! lol
Found P132 but its attached with A or B not ;
and no luck on searching for P-#06..
Truck won't start when hot, i have seen variation of the cause of the problem from cam sensor to hpop fittings to the hpop itself. if anyone can point me to some insight according to the error codes would be much appreciated!
I originally was having fcim issues, when and purchased a new one of those then this started happening right after the new one was installed. Figured that would be worth while mentioning.
Wamphyri is offline
post #2 of 7 Old 08-03-2013, 09:16 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
can you monitor icp? if so what is your reading? It sounds like a hpop leak. Do you have updated dummy plugs and stand pipe? You really need to know what your icp is and ipr% this will tell you if you have an hpop problem.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 7 Old 08-03-2013, 09:25 PM Thread Starter
unfortunately not, the bully dog just reads codes, doesnt truly monitor vitals, does anyone know of a shop in essex county, ontario canada besides the stealership that can read codes and test the hpop? or a way i can test the hpop myself?
Wamphyri is offline
post #4 of 7 Old 08-03-2013, 09:44 PM
try this.
DIAGNOSING A 6.0L HIGH PRESSURE PUMP!
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #5 of 7 Old 08-03-2013, 10:01 PM Thread Starter
wouldn't a shot sct gasket gurgle like that as well?
Wamphyri is offline
post #6 of 7 Old 08-03-2013, 10:05 PM
I do not know for sure but if you have an 03 you do no have a sct fitting. Maybe you can pm a tech or someone with more experience can chime in.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #7 of 7 Old 08-03-2013, 10:14 PM Thread Starter
thinking at this point i might be better off just bringing it to a shop i think and having them test/figure out whats going on with it
Wamphyri is offline
