Momentary Bugaboo That Goes Away Quickly After Starting Out - Ford Powerstroke Diesel Forum
post #1 of 49 Old 08-02-2013, 01:32 PM Thread Starter
My 2007 F-350 6.0 w/ 210,000 miles, runs kind of rough and is way down on power when starting out from cold. Evidence of being down on power, is that transmission goes to much higher RPMs than normal before shifting.
But this "problem" virtually goes away after 2 or 3 minutes going down the road.
Also, if I just start the engine and let it idle, it idles very sweetly (i.e. not roughly at all). I have no doubt also, that if I simply let engine idle for 5 or 10 minutes before starting out there would be no problem at all.
Any ideas?
Aufgeblassen is offline
post #2 of 49 Old 08-02-2013, 02:19 PM
This is where one of those monitoring devices comes into play....
Without some basic info from monitoring engine/system function you are in the dark
First thing I'd check is FICM voltage, but with no more info to go on, it's just a guess.
darenative is offline
post #3 of 49 Old 08-02-2013, 02:31 PM
ThomasvillePavers's Avatar
Jeez, will the mods please just shut this clown down!!!!!
BAN THE OP
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #4 of 49 Old 08-02-2013, 03:15 PM Thread Starter
BAN THE OP
Clown??? You think I am making this up???
What is the matter with...YOU??? Your momma didn't love you enough???
post #5 of 49 Old 08-02-2013, 03:18 PM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
I think his problem is that you ask for advice, when you get advice you decide that it's not the correct advice, even though it comes from members who know what they're talking about. That might have a little something to do with it, maybe, just a little.
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #6 of 49 Old 08-02-2013, 03:28 PM
Some advice to the OP. these guys know their stuff. Without a moniter and some basic numbers, it's a crapshoot. Your problem could be anything at this point.
Your post is very low on details. Get some more info and you'll most likely get it figured out.
Moto2four is offline
post #7 of 49 Old 08-02-2013, 03:45 PM
Quoted: 760 Post(s)
Any ideas?
Didn't I already answer this question in your post about your tires. That I also told you needed balanced???? And wouldnt listen.
Corey@CNCFAB is offline
post #8 of 49 Old 08-02-2013, 04:11 PM Thread Starter
Yes and no. You did say "That is normal because of your EBPV", however you did not explain what "EBPV" is, so therefore your answer is useless.
I'll take a guess here: Exhaust ByPass Valve??? And if so, is said item malfunctioning?
post #9 of 49 Old 08-02-2013, 04:20 PM
Fantom's Avatar
Quoted: 12 Post(s)
If only this website has a search button. Maybe somebody should message the powers that be and tell them to add a search function. You know, for searching for common answers to common problems that are commonly answered.
John
100,000 Miles
Fantom is offline
post #10 of 49 Old 08-02-2013, 04:21 PM
Quoted: 760 Post(s)
Lol. You beat me to it Fantom. :thumbup:
